In the Boot.
Undo the negative side first and push it to one side.
Next undo the positive but don’t try to pull it off yet.
Loosen the clamp bolts
A magnetic pick tool is good for retrieving the nuts
Remove the top strap
You can then remove the metal clamp plate
And now can slide the battery over to the right a little to give enough room to remove the positive connection and plastic cover attached to it, *tip*-pull the plastic box out to the left then gently up to remove it and the positive terminal, it has a tab that locates under the battery side.
Lift out the old battery, withdrawing the drain tube as you go.
Put in the new battery and insert drain tube into the hole.
Clip in the positive terminal and black box then tighten the connection up.
Put the bracket back in and refit the left hand nut (a magnetic pick up is handy to start it on the thread here)
Refit the plastic shield on top of the new battery
Put the strap back on over the battery and refit the nuts then tighten down.
Reconnect the earth/ negative and tighten
You should end up with this.
Coding.......
In VCDS
Leave this as Fleece
Manufacturer in here
The box below you could just put zeros in I’m told as new batteries don’t com with BEM numbers.
I put in the Varta ref number off the new battery
Standing voltage is now 12.45 (and was rising). Up from 11.80 of the old battery
