Evening/morning all
Recently purchased a 2012 Rs3 8P 25k on the clock and I'm really chuffed with it after upgrading from a S3.
I've noticed a few issues since driving it and have already booked it in to Audi whilst it's under warranty.
I ran a scan on it and I had several faults on the car.
1 - 02619 - communications wire adapter set
(After some research it appears as though this is a common issue since the RSNE software update). Will not reset.
2- I have an iPhone 6 and the lightening connector won't connect to my phone in order for me to play my music. Not sure if this ties in with the fault above (02619) just seems a bit ironic. Anyone else have the same issue? I did read that iPhone 6 have issues with the MMI system.
3- 00448 - Haldex clutch pump (V181) (research shows that when this fails the car isn't running at AWD.) I reset this and have since drove the car a few hundred miles and run another scan and this hasn't returned.
4- Vibration through the steering wheel when braking but I have read numerous threads on this very common issue. When I purchased the car the pads/discs were changed approximately 1k miles ago. The discs have the 'B' on them along with the Audi campaign NSF arch mod. So I'm going to see what they have to say at my local dealer.
5- the glove box damper has failed, I assume the previous owner always used the lightening adapter (doesn't work now) hence why the glove box just drops. I have never had one of these failed on my A3 & S3 but I'm sure Audi will see this as wear & tear or damage.
Any information or experiences i would appreciate.
Ta
Ta
