Hi, the tips are welded on so not sure it’s easy to change them without replacing the entire back box!Hey
I was looking to change the stock exhaust tips with something just clean and fresh looking.
Any ideas on the best places to source these? I have a FL sportback.
Thanks.
Sent from my SM-G981B using Tapatalk
Some have just re-sprayed their tips @T-1000 i recall did a great job.
Look great . How did you do it if you don't mind me asking? Which products did you use?Indeed Riko and a year on still look great.
Is one can of the foliatec 250ml? How many coats did that get you on each exhaust? Thinking about doing this just checking how many cans I'll need to get? ThanksRubbed them down with wet & dry, degreased them, masked up the rear and 6+ coats of Foliatec gloss black
Thank you. Only problem now is trying to find a supplier who has stock and will deliver to UK!Yes 250ml
Around 7/8 coats each from 1 tin so plenty.
I did see this one! Only thing I wasn't sure is the description said black instead of glossy black. Wasn't sure if this was maybe a matte black alternative.RTECSHOP.co.uk | The Alloy wheel and tyre specialists in St Albans
The Alloy wheel and tyre experts in St Albans, Hertfordshire. Shop online for all your car upgrades, styling enhancements, exhaust systems, suspension and more.www.rtecshop.co.uk
Good spotIf you read the description it says available in gloss black.
HiHey
Thanks.
Great work!Hi
My 2019 sports exhaust tips are flaking... a bit of too and throw with audi and they are being fixed... Audi suggested cutting them off and replacing the black ovals... but we decided it would be best to respray. Also had a result on the crappy rear hubs... They are replacing the rear discs and pads too... very surprised but will happily accept.
HiGreat work!
Can I ask which Audi dealership agreed this?
My local dealer said a while back it was something Audi were looking into but at that point couldn’t offer any help.
They did replace the whole back box on my previous S4 which badly corroded but as a one off gesture, 6 months later it was nearly as bad so I reckon your replacement tips/exhaust will just do the same again sadly, painting it would seem the better option to make it last?
Hi
It was Cheshire oaks Audi. The tips were easy but the rear discs took some persuasion Audi UK said to cut them off.. i wasn't up for that so it's going to their local body shop.
Hi yes the car is only 18 months old. With 8000 milesIs this under warranty?
