Evening all
I've recently moved into a new build type property which is brilliant and have done some little mods to my garage to make my car cleaning experience that much better.
Added a hormann sectional garage door and cut out the rear of the garage to access the back of the garage through my garden. (Previously I had to walk around another property adjacent to me to access my garage - slightly frustrating)
So now I can run the hose through the rear door and once I've re wired the garage I can clean away...
My next issue is because the garage area is compromised of 6 garages (3 garages facing each other with one entrance to them) the only drainage is slightly offset from where water would run down if I was to clean my car. It would probably run down the drive and into the garage opposite me - and if it was the other way around I'm sure if I had snow foam entering my garage or touching my car it would get on my t*ts.
Which leads me to my question:
What are the rules/ regs regarding adding drainage on my space in front of the garage to avoid water going everywhere. I've seen some gulleys that suit my need but I'm sure there will be some legality that will stop me redirecting the water into the drain
Thoughts? Or other ideas?
