New TQS Owner & Project
MaverickTDi
No, the ABS rings are on the driveshafts so are not affected by changing discs
Right I see. Never changed the discs on a b5 before and with reference to 'brake kits' (discs, pads, abs rings and wheel bearings) I've seen on eBay it implies the abs ring is somehow attached to the disc - well that's the way the picture makes it look.
Consider myself suitably educated.
MaverickTDi
Evening all, I'm hoping to get a little more opinion on my hesitant starting issue.
Despite replacing the CTS and a questionable vacuum hose the fault, intermittently, still persists.
As can be seen through this thread I've ran VCDS no end of times and it picks up nothing and all monitored parameters using VCDS Lite seem good.
Interesting to note that when the car starts to hesitate (4-5th crank) if I put a little throttle input in it fires.
Could there be something more mechanical to blame i.e. throttle body?
Any thoughts?
Cheers.
aragorn
"Stick a V8 in it!"
Staff member
Moderator
I had similar weirdness some time ago. Swapped out the n80 valve and it sorted it.
As a test you could remove the engine side hose and blank it off. Leave the n80 side open.
MaverickTDi
Cheers mate - I'll give that a try.
Typically I don't use the car for long trips - daily use is about 5 miles a day. However, I done a 100 mile trip Monday and starting has been fine since - see how it goes...
Is this the N80 valve location on a b5?
Cheers.
aragorn
"Stick a V8 in it!"
Staff member
Moderator
yep thats it
MaverickTDi
Evening all, as I had a few hours to myself this afternoon I thought I'd change front & rear discs and pads.
With it being such an easy OEM+ 'upgrade' I took the opportunity to do the 312mm front disc conversion.
Fronts before;
Difference in disc size against original;
After;
Rears before;
Pad worn to metal!!!
After;
I used Mintex discs all round and for rear pads. Front pads are Ferodo DS2500.
I still have a mechanical 'whirring' sound coming from the back axle when I apply the brakes - must be a wheel bearing.
For anyone who's interested in the 312mm upgrade - it was relatively inexpensive. For any TQS owner you just need the bigger discs (for a b6) and some Mk1 TT/S3 carriers. All in it cost me £150.
MaverickTDi
Afternoon all,
Well the car passed it's MOT on Friday with only 2 advisories - minor oil leak and minor windscreen damage - well chuffed.
However, after changing the discs and pads on the rear I notice that both springs were snapped at the bottom . They have now been changed - can't say I've noticed a difference.
Samuel c5 Q
Silver Supporter
Did they pass the mot broken?
I have one broken spring at the minute. I've noticed in the past that the height of the vehicle, shock length make a difference in transferring weight which would affect loading and grip levels. You might notice the difference if you flog her on a bit.
MaverickTDi
They were changed just before MOT - I told the garage they were broken - would have been a failure otherwise.
Now you say that I noticed that the rear of the car looked like it was sitting high and my TQS sits on 18" RS4 reps.
I tend not to thrash her tbh - saving that for track days!
Samuel c5 Q
Silver Supporter
I noticed your tqs was sitting high at the rear? Don't remember but I know when the back of my Cordoba is high she tends to roll the back end about and it can slide out like over steer. When it is squat and lower the back stays planted and she pushes the nose a lot more.
Tyres and wheel have a big impact on road holding. Me and my friend that owns a garage found that sometimes too low a profile tyre can lead to less feedback and more sudden traction break away. Leading to lower cornering speeds and overall longer lap or journey times.
aragorn
"Stick a V8 in it!"
Staff member
Moderator
If the springs are aftermarket, they will be "normal" height rather than "sport" height. For some reason no-one makes springs for cars with sports suspension, so if you fit aftermarket springs it ends up looking like a tractor.
The only solution is either going direct to audi, or better, getting an eibach pro-kit.
MaverickTDi
Afternoon all,
Just after a bit of advice/clarity. Both my rear springs were snapped and I've had one replaced but it now sits considerable higher on one side;
N/S - new spring;
75,0mm from tyre to wheel arch.
O/S - old spring;
50,0mm from tyre to wheel arch.
I'm sure I've read threads about Pt No mix ups between TQS and non-TQS models but was wondering if anyone can definitively tell me what the Pt No is for a standard TQS rear spring?
Cheers.
aragorn
"Stick a V8 in it!"
Staff member
Moderator
MaverickTDi
unless they bought the spring from Audi, it will be a standard height non-sport spring.
The correct solution now is to go and buy an Eibach Pro-Kit:
http://www.ebay.de/itm/Eibach-Pro-K...340882&hash=item20d02c2331:g:YxQAAOSwcUBYSGrv
The springs from audi are £120 each, makes no sense to do anything other than buy a complete kit.
Cheers mate.
I've got in touch with the garage to see what spring they've fitted.
From memory they charged me £70 for the spring so my guess is its non-OEM.
MaverickTDi
Any chance you could point me in the direction of the N80 valve I need?
Tried eBay and the likes - no joy?
Cheers.
Samuel c5 Q
Silver Supporter
Is your old definitely defective? You can use a test lead to activate the solenoid whilst blowing through it to check for flow in the correct directions. After you clean it that is.
MaverickTDi
Tbh I'm not sure - figured for the price I've found other N80 valves for other Audi models (£26), I'd just change it and see what happens.
I'm basing this on what Aragorn said a few posts back as it can still be hesitant to start and nothing comes off VCDS.
Cheers.
aragorn
"Stick a V8 in it!"
Staff member
Moderator
058133517 is the part number for the AJL valve.
MaverickTDi
Thought I'd give the old girl a good maintenance wash today;
MaverickTDi
Been reading your thread thumbs up mate currently modifying a a4 b5 avant 1.8t
Truth be told I was after a TQS Avant but there were no good ones when I was in the market. I used to have a TDi Avant - loved it.
I have no immediate plans to tune my TQS but make it a really good original example - the list of things only ever seems to grow, funny that isn't it
MaverickTDi
Lol yes mate trying to go down the bex turbo route currently on 190 bhp want more haha
I think that's the route I'd also take mainly for ease and power limit. 230bhp, imo, is plenty enough and coupled with a good suspension set up it would be a joy to drive.
If I were in pursuit of 300bhp+ or just outright power I'd start with then S4. There's a red b5 RS4 Avant in my village - what a weapon!
So other than engine mods - do you have anything else planned?
Andy avant b5
I've got a couple of threads going at the moment fitted some recaro seats that I had to custom make some frames have some pics up also did the 312mm break upgrade what a different it makes
MaverickTDi
Cool. I really like the stock TQS seats - 1/2 leather and cloth. I might look into having the leather sections (bolsters) changed for alcantara in the future.
Yeah the 312mm upgrade is a great OEM+ mod and as you say improves braking performance. Would love to try and fit some Bentley continental rotors - saw them once on a Mk5 GTI and looked insane- would be purely for show as you'd need an extra 50bhp just to cart them about
Andy avant b5
Lol have the same alloys as your but looking to swap mine for something else not sure yet next job are coliovers next weekend not sure after that hopefully Santa comes down the chimney with a intercooler in he's sack
MaverickTDi
I don't like the RS4 reps - came when I bought the car. I've since sourced a full set of original TQS Bolero wheels - just need a refurb ready for next summer. I've seen a few b5's running Porsche wheels - look alright to be fair.
What coilovers have you gone for? I'm thinking of going down the Bilstein B12 pro kit route.
Samuel c5 Q
Silver Supporter
I have an a6 but bilstein and eibach would be the way I'd like to go. I'd be interested to hear how they work for you.
MaverickTDi
A little mini Mod today;
B6 1.8T engine cover fitted.
Before;
After;
However, the bonnet strut is on its way out, it kept sagging - one job off the list another one added
Samuel c5 Q
Silver Supporter
I get stick for doing too much car work and then get grief when they aren't running right, can't win.
