Newbie after advice on retrofitting
Daniela3
Hi all I brought a Audi A3 S line recently 2016 model I have been browsing the forum and interested in doing the following retro fits
Auto lights - what code rain sensor would I need and headlight switch ? ( I have xenon headlights with front and rear fog lights )
a boot subwoofer - I can see a subwoofer on the internet for sale but not the connector ?
also interested in retro fitting a cruise control and that will be me happy
Any help would be greatly appreciated
thanks
Dan
leonwilliams
Hi I'll start from bottom of your list cruise is simple get a used on and the cowel it then needs coding. On the sub if your fitting new head unit with amp it's simple I have 2011 sportback with amp I just added amp and a sub to run alongside existing sub sounds great. On the auto lights bit more complicated. Was thinking of that but needed module and other components.
kpm278
Sub can be connected upto existing unit without extra amp if desired. All the info you need is available on this forum. I did all three - cruise control (fitted and coded by DJAlix), auto lights and rain sensor, and sub/centre dash speaker. It was two years ago so I can’t remember the detail, but I found it researching on the forum
Daniela3
Perfect the cruise control is the main must have for me to be honest you would have thought buying a Audi sline 2.0 diesel it would have at least be fitted with cruise but never mind. I have checked my existing sensor behind the light for the auto lights and switch I think I have the standard humidity sensor fitted at the moment I have had a brief look and you need to change the mirror sensor and the light switch to an automatic one just looking for some part numbers for what I need for them. I’m sure some more will have there input soon
thank you
Dan
kpm278
Cruise control can be fitted yourself but you have to get it programmed by someone who can connect to Audi online. For the price DJAlix charged I was happy for him to fit and program. He did it in about half an hour without tools. Wizardry.
kpm278
These are the parts I ordered for the sub and centre dash speaker (fits under the grill behind the pop up display):
1 x 8V0035397 audi centre speaker £18,00
2 x N90930201 centre speaker screws £1.00
1 x 1J0971972 centre speaker connector £2.00
1 x 8V0035382D audi subwoofer £90.00
1x 4E0971942 subwoofer connector £2.00
1x 5Q0803899 long spare wheel screw £10.00
you’ll need wiring obviously, and you’ll prob need a bigger space saver wheel for the sub to sit in
kpm278
The sub and centre dash channels can be switched on with vcds I believe, but if you want the separate subwoofer control in the mmi you’ll need odis.
the rain and light sensor can be switched on with vcds once you have the parts.
leonwilliams
There's these subs I'm thinking of getting one
kpm278
Probably a fair bit better than the standard sub, but I liked the idea of keeping it factory, plus it wasn’t expensive to do and I do get a nice rumble from the standard sub. In fact most of the time it’s at half power in the MMI. What the Audi sound system does need though is a bit more mid range. I saw someone retrofit mids in the middle of the doors near the handles.
leonwilliams
I've a 10" JBL in a box sounds sweet keeps base inside car and your right about lacking mid range
Daniela3
Hi mate does the difference on the sensor B or C at the end of the code make any difference ?
Daniela3
Did the rain sensor come with the gel pad people are on about or would I neee to buy separate.
Thank you
Daniela3
Hi all I have fitted a light sensor 8U0955559C. When I spoke to Audi they said that 8U0955559B has now been discontinued and that 8U0955559C is the new replacement for this. I fitted a new light switch 8V0941531L which is exactly the same as what I have fitted but with just the auto option. I have managed to get hold of some one to code it but it keeps saying Coding is incorrect would this be due to it having 8U0955559C Rather Than 8U0955559B
Please Help :weary:
I have a copy of what it says here
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061521801160
Coding: 07040A42C24122DD03804004B11807A80000000000000000000000000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 0913C0E6A8394B07F0-805C
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 150729 042 0585
Serial number: 150810223019
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 62993912
Coding: 0B006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 L HW: 8V0 941 531 L
Component: E1 - LDS MQB H05 0032
Serial number: 06 05 2013 00000680
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY151771ECA
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000033157953
1 Fault Found:
526359 - Control Module Incorrectly Coded
U1014 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 208
Mileage: 59579 km
