christopher barnes
Hi guys, noticed my heater blower wasnt working, all direction and heat ok. No a/c. I tested the fan using a 12v supply which was fine so i then lazily ordered the heater resistor thinking that this was the fault.
Fitted the new one and again no blower, so I started re testing the fuses which all tested ok using a multimeter, this time i actually took the fuses out. When i removed fuse number 5, the blower started working, alas the A/c wasnt cold tho, put the fuse back in snd the blower stops again (5 amp fuse is fine). Could someone point me in the right direction as I cannot find any info on this. I have ordered a VAGCOM disc so I can scan the car. Ive left the fuse out so at least I have heat available. Picture of the fusebox lid, its fuse number 5, AC, heating diesel.
