Hi all,
Usually I don't really open new threads as I like to search and search I really appreciate this form for the information that i find tips and etc and the helpful people that sign in every day to help each other and share experiences.
This time I am stuck and seeking your help.
Iâm suffering from the occasional over boost and "Limp Mode" this has happened before the remapping and after the remapping. I'm afraid of putting my foot down now because of going to limp mode and finding a place to pull over to switch off my car and start up again.
Before taking my turbo off and giving it an hour clean which is not a problem but the hard bit is taking the turbo out which is a nightmare for me, where do i look else? boost pipes? recently replaced the inter cooler pipes left right because of joint split i have checked them they OK for now also the pipe that connects to throttle body used to leak air but now i have tighten it with jubilee clips.
Thanks and your help is much appreciated
A3 8P 2004 2.0TDI over 100k
5 Faults Found:
16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
P0234 - 000 - -
Freeze Frame:
RPM: 2709 /min
Torque: 360.0 Nm
Speed: 118.0 km/h
Load: 72.5 %
Voltage: 14.44 V
Bin. Bits: 00101000
Absolute Pres.: 2315.4 mbar
Absolute Pres.: 2590.8 mbar
16618/P0234/000564
16618/P0234/000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
Possible Symptoms
5 Faults Found:
P0234 - 000 - -
Freeze Frame:
RPM: 2709 /min
Torque: 360.0 Nm
Speed: 118.0 km/h
Load: 72.5 %
Voltage: 14.44 V
Bin. Bits: 00101000
16618/P0234/000564
Possible Symptoms
- Malfunction Indicator Light (MIL) ON
- Boost Pressure too high
- Reduced Power Output
- Hoses incorrectly connected, disconnected, blocked or leaking
- Boost Pressure Control Valve (N75) faulty
- Boost Pressure Sensor (G31) faulty
- Turbo Charger stuck/faulty
- Check Charge Pressure Control System
- Perform Output Test (to check the Turbo Charger)
- Perform Basic Setting (to check the Charge Pressure Control)
- Perform Pressure Test to locate Leaks
- Check/Replace Boost Pressure Control Valve (N75)
- Check/Replace Boost Pressure Sensor (G31)
- Check/Replace Turbo Charger
