Hi everyone, wonder if anyone can help me out with a problem!!!!, I've had my 2004 b6 1.9 TDI quattro nearly 6 months now, 169000 MLS with fsh, since having the car I have spent most of my time sorting out various problems instead of enjoying it ( replacing window actuators/aircon compressor pulley/etc) usual stuff I suppose considering mileage and lack of general tlc and now runs pretty good but wouldn't say fuel consumption is anything to shout about, anyway there is 1 problem I just can't get to the bottom of, I keep getting this grinding sort of noise coming from the drivers right side and it feels air related like a dry sucking /vacuum noise as though coming from the Airbox area ??, and the car seems to pull back as though something is stopping it and loses power, probably limp mode, i have had the Airbox off completely and changed all the vacuum hoses and have also had the intake manifold off (very gunged) and cleaned all with Mr muscle including inside the turbo vanes and also replaced the air filter, upon road testing I thought I had cured the problem but unfortunately not, sometimes it feels as though the turbo is not working (over boosting) accompanied by this dry grinding sound that you can hear whist driving, funny enough it also seems worse whilst cornering ????, I've also checked the Maf by disconnecting it and road testing but the car seemed worse when road testing although I didn't get any engine management light come on when disconnecting it ?definitely seems to come from airbox/ turbo area when blipping the throttle, I have checked for any codes via vcds lite but no error codes, I just don't know what else to do now, I have also disconnected the vac lines whilst engine is running and there seems to be a vacuum, problem is this fault is intermittent and sometimes the car runs great with all power and no noises and then another time it is like this, doing my head in !!, Am I missing something ??, Also not checked n75 valve or the other valve connected but they look ok and if you disconnect them you lose vacuum so thought these should be ok, ANY IDEAS ANYONE PLEASE !!!!!!!
