Not another Nogaro!!!
S3 is now up in the drive ready to be stripped.
Reactions: <tuffty/>
Operation OG - lets go.
546B7E09 0F66 4ED8 A97B F8A28CF906A3
Fluids drained, all electrics unplugged and almost ready to pull.
FFD9F9E8 5988 4427 9C82 BC4AAD1A2735
I love the way you hold your hair before jumping into the car Ian..... very politically correct
Reactions: Tj 0785 and superkarl
Don’t get to down about it mate, I thought you pulled it off very well, with style!
Cracking on!
Lifting this out of its temporary resting spot.
4A0F6FA9 189C 4990 9771 800647BDE1AA
91A788B5 865C 4E3E 8511 5C4CACF5DEEA
Giving some love while it’s out
FA247F61 64CC 401A A45F BEDE935611CE
0A7EE3AA 90B9 4626 ABAE 07057C93B04A
Cute!
BA5C511C 6BF6 4CCC BF0A B5730C4EDC74
Almost ready ...
910873C0 5012 48CE BBBE C754A4047677
My worst enemy - the downpipe!
FABF6709 449E 4A6F B6BA 4612D45CE0F3
I am so confused.
So, If I'm reading this right, you stuck a v6 in it, and it's now going back to a BAM?
Reactions: IPG
He is going full hairdresser mode... V6 in a drop top TT...
Reactions: Tj 0785
I just want to feel the air in my bouffant :glee:
No no... in the end the red tape to have things “officialised” to just sell wasn’t worth my time and headache making appointments to get tests done on the emissions, brakes, the SRS system (basically one engineer telling me I’d need to crash the car to prove the SRS would work with the VR6 in it... wtf!!!) and other hurdles - it was quicker (clearly) for me to just change it all back for the reason of selling.
Both the TT Roadster and the S3 ...
Got the body/o2 side harness in this morning so now the 1.8t can swing back in. So much easier to fit it than the 3.2!
Now where are my curlers???
Reactions: S3AMJ and <tuffty/>
Pushing on...
3DE4B767 047D 44EC AA01 4510F9981E27
Engine loosely bolted in place at the mounts.
951C9EC2 C92C 4678 9D9E 6B2D315D2632
580328DB 482D 4899 8F96 C0EDBE44C803
Quick oil and filter service while it’s super easy
02365B83 11B9 4690 9ED8 B6955E02A4D0
Had to change the fuel filter back over to the return system filter VS the returnless from the 3.2
EDAB6A37 75A2 46F8 90D6 546B139EB8BE
A39AB271 CAF9 4D8B A68F 570AA5EED062
Intercoolers on! Back to turbo from N/A :icon thumright:
FD2B4341 5D61 47D7 A3CC 3021C35D4CCC
94A902A6 E5A8 4004 9FA7 711EAD3D589D
All other intake and vacuum pipes hooked up for a quick crank and 10 second idle.
:nogarors4:
09ED2910 E5A7 4D11 92F9 831F9FF8866F
B4625333 CB06 48FA BEB5 CDC88D043AF1
... and time to tackle the small things that make the car work properly.
Dum Dee dum!
Reactions: hydro s3
Your 3.2 was the later engine then with the cast crank if it had return less fuel system? Mines got a return :)
Nah mine is a BML :)
Definitely forged crank
you wanna see a pic of the car it was from? it’s quite a sight to say the least!
I used the mk5 rail because it came with injectors and was the most cost effective option at the time due to my kit missing them - plus it is FAT compared to the mk4’s rail. Along with the shallower/baffled mk5 sump.
The S3's first drive - back as a 1.8t.
Good to hear those turbo sounds again! hahaha too fun :nogarors4:
Reactions: Tj 0785
Been putting this job off for ages where my headlight had dropped.
Looking inside the ball joint broke off the adjusting section leaving the headlight pointing directly down.
heated up the light in The oven and pried it open
212BC4C6 2A71 4AFE ABD8 A8DB2BBE0601
love this etching detail
D07A1803 8AFB 4FE4 BF47 F1E982390655
The broken bracket which was replaced by an upgrade part by Trups
E21B5C45 CC5E 4DCE 80C0 F1D32B514C43
Just need to wait till it’s dark to get on with adjusting.
If that's a 3d printed part mine broke twice with them. In the end he had to order a new headlight and swap the parts over which worked no problem. Good luck
yeah the white ones are - i have been given a revised version of the 3d print and it's made out of a different material so i am hopin these ones don't snap like the one on the right :(
I changed them both in the one unit so finger's crossed!
Well if it's a revised version of it hope they work better but on the material they are made of he said his mate had use the hardest material he could use but hope you have better luck and works for you.
So for completeness sake I’m going to post the one last pic I’ve taken of Noggie before moving him on.
8FB7B400 70E3 4ACB 81EE EE688994F519
Me and that blue chunky butt had a great time, as documented, and has now been moved on to a keen as a beam younger guy who I am sure will take good care of him.
I told him to. Hahaha.
Props to everyone who has pitched him over the years, you know who you are, and long love the 8L’s! :nogarors4:
Reactions: hawesy25, S3AMJ, hydro s3 and 2 others
Hey guys - it's been a while! This post isn't to say another S3 8L has come to my possession but just an update to the below if anyone is interested.
So... this happened today...
01
There were talks of swaps and upgrades which has been utterly successful. The build thread isn't here but on TT Forum FrankensTTein 3.6 build thread. To get to the part where the project has come together you want to CTRL+F or CMD+F search the word corona which takes you to the link. Many mods and upgrades were done to the black, base model, FWD TT Mk2.
I'm still very much in the 8L gang here in Aus. People are still interested in colourMFA and there a few big builds going on which is great! In the meantime if you guys did want to check it out here's the link again:Black B7:
825
31
6K
90
15K
