Hi Guys,
I have a problem with my gearbox when the car is cold.
Changing gears from 1st to 2nd feels notchy when it does go into 2nd, but sometimes its hard to put it into 2nd at all.
When that happens I have to put the lever back a bit and try to engage 2nd again, and then it goes in.
Sometimes when 2nd goes in, there is a single clunk sound.
There is NO synchro grinding sounds at any point.
This doesn't happen all the time, and sometimes it shifts smoothly into 2nd when cold, but the problem happens often enough to annoy me and think something is wrong.
When the car warms up, everything works perfectly and its a joy to drive.
I recently had the clutch and DMF replaced, because the DMF was gone bad.
Since the gearbox was out of the car, I had 1st and 2nd gear synchros replaced too, because I had trouble putting it into 1st.
(the mechanic said 2nd gear synchro is worn too, so it was also replaced)
Given that the synchros are new, and everything works perfectly when warm, I think the issue is somewhere else.
I did some research and came across this thread: https://www.audi-sport.net/xf/threa...gear-changes-when-cold-2-0-tdi-s-line.201592/
People are saying that notchy changes from 1st to 2nd are a common thing and some Audi cars have that problem from new.
I read there that a thinner oil with specification G 052 171 A2 solved this problem for many people.
The standard oil apparently is spec G 052 532 A2
However, that thread is quite old, and the car in question was a different year than mine.
So I wanted to ask to confirm if changing the oil would be worth a try in my case as well.
My car is a 2016 A5 B8.5 2.0 TDI Sportback, CNHA engine, 140kW, 165,000 km on it, with the 6-speed Manual 0B1 (front-wheel drive) PJD code gearbox
