Oil inspection service
Sug
Inspection service is due in 2300 miles / 30 days and next oil change in 5500/84 days. I will be lucky to do 2300 miles before feb. I never had these separate intervals with the S3 do I have to stick to the 30 days and 80 days to keep the service records in check? What is involved in the inspection and any ideas on a rough price at Audi? Can I wait on the inspection and get them both done in 80 days?
Callump01
From what I hear, it can be pretty pricey for just an oil change (~£340)
Take it with a pinch of salt as I haven't tried it yet, but apparently Audi will price match Halfords if there's one near the centre. Just go on the website, put in your reg, select interim service and the oil upgrade option, then go to the basket and print that screen. It'll work out around £150 according to @JamesBaby but you might have to shop around for an Audi centre that will agree to it.
Sug
Just rang to get both oil service and inspection done at the same time as there only say 7 weeks between the two and it was £511. (Harrogate Audi) Jesus
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
You shouldn’t have to pay for both, it’s one or the other. Both come with an oil change, it’s just whether you need all the extra bits that come with the interim.
Sug
Rang Leeds Audi they said £450 for both then added pollen filter and brake fluid change and came out at £620 car has only done 16k.
Sug
So let’s say I go with Harrogate Audi at £511 how can I get this price down, take my own oil for one? Ring around other dealers in area? Do I need a fresh set of plugs at 17k?
DW81
New plugs at 19k. In all honesty mate save your money and take the car to a vag specialist. Will not be stripped up in the price and will no doubt be better looked after. Or if your upto it buy the parts from Audi and do it yourself if your planning on keeping the car long term
terminator x
Afaik inspection isn't an oil change it's just Audi having a look around the car! Oil changes are every other service so 2 years or 18k miles ish.
TX.
Sug
I normally use my local specialist for servicing or repairs but as this RS3 has warranty until Nov 2019 was hoping to use Audi for servicing. I take it as long as my servicing is done at the correct time and a full run down of parts/oils that are used are documented then warranty will stay intact?
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
TX.
It’s always been my understanding that Inspection is their word for major, this is how Long Life servicing is a scam... you have 2 oil changes in one Longlife cycle if the oil change and interim don’t coincide with one another.
terminator x
There is no "major" service albeit they do other things mileage dependant eg sparks every 19k, gearbox oil every 38k ish etc.
TX.
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
TX.
Every day is a school day, thanks!
Spark plugs every 19k... the service requirement list that Audi sentence me said 40k?
DW81
That is my understanding too and that the garage undertaking the work is also vat registered
DW81
After changing both mine a couple of months back and seeing how black the gearbox oil was I would do mine every 20k or two years. Might be abit ott but £100 for oil and filter compared to £7k for a new box is piece of mind for me. The Haldex was extremely clean to be fair but for the cost of a litre would do this the same time too.
R
RS_Dan
Guest
Is that at a main dealer? My cost is £225 according to the fixed price Audi website
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
Nearly as laughable as the Haldex coupling oil / DSG oil change intervals........
Even better, just went to book in my granddads 1.4TFSI S-Tronic, lifetime oil... gearbox is a sealed unit they said and they can’t change the oil. Ok.....
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
Your feedback when you had it done made me conclude that I’d have it done in half the time. Whatever Audi recommend, like the plugs at 40k, haldex oil every 3 years and the gearbox at 38k... I will have the same service done at my specialist when I get to the half way point.
DW81
Hi From one Dan to another no this was the cost of parts (there abouts)ordered from Tom at Crewe Audi and about 1.5 hrs of my time at another owners place as he had vcds to hook up to the car to monitor the oil temps. The Sealey pump I bought (t800 recommendation) cost about £70 and probably shaved at least 60 minutes of the job.
It’s quite a straightforward job but like anything you have to be methodical.
The Haldex was about £40 1litre of oil and the draper pump I used on this was £12.
I went the extra mile on this and unbolted the precharge pump off the Haldex unit just to check the gauze was not clogged up which it wasn’t. This takes about 60mins all in
DW81
The stronic oil did look abit sorry for itself but if it makes you sleep better at night matt go for it mate.
R
RS_Dan
Guest
Cheers Dan, my car has just gone over 30k so I think I'll get the gearbox oil and filter done now.
Rs1
Is £350 about right for oil change and 1st Inspection..been ringing around Audi dealers up to £490 been quoted!!!!!
Audi specialist independent charging around £280 so going with £350 to keep Audi original service history...this is the Facelift car if makes any difference.
LuckyLee
I originally got quoted £330 for my first oil change on my FL by Audi last week.
I got a quote from an Audi specialist for £185.
Just by speaking to my Audi dealership and mentioning the price promise. They said let’s see what we can do. After a few taps on the service computer I got a new price of £215, which I was happy to pay. Well worth mentioning the price match and asking to see what they can do with the price ;o)
