Hi guys!
It all started after a clean up and tire change.
One hour after tire change front right side air suspension said psssssttt and lowered to the bottom.
It was changed at Audi center and after change they said that there is intermittent fault on Level Control circuit 15. They said it wont affect anything but do you want it to be checked for 155€/h. So I said no. After few weeks I got warning Air suspension fault but everything worked. After few days glow light started blinking every time if I floored the pedal or calmly accelerated over 100 km/h and the car went to limb mode. When I started car again everything was fine but after few kilometres the suspension fault appears again and again after acceleration goes into limb mode with the blinking glow light. It also noted that oil change needed in 200 km. So I took the car for oil change and also replaced all the filters and hoped this will fix the limb mode, also changed the 644 relay from the boot to hope it to fix the suspension fault. Well nothing came fixed, but the very next day I got one more warning light, the engine light came on while driving, also I noticed that the oil level had dropped. I opened the engine room and I saw that there was fresh oil on somewhere where it shouldn't be and after starting the engine again the engine wobbled and made the whole car shake.
Can anybody help what is going on with my first Audi?
Here are pic where is fresh oil
Here is also the fault codes that I found with vcds:
Code:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 18 19 20 28 34 36 3B
3C 42 44 46 47 52 53 55 56 5F 62 69 6C 6D 72 84 85 88 89 8B
8E 8F 90
VIN: WAUZZZ4G1BN031480 Mileage: 238005km-147889miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
84-Night Vision -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
88-Multicont. Seat Driver -- Status: OK 0000
VCDS
Self-Diagnosis Log
Tuesday,01,June,2021,12:31:31:00009
Page 2
VIN: WAUZZZ4G1BN031480 License Plate:
89-Multicont. Seat Pass. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
VCDS
Self-Diagnosis Log
Page 3
Address 01: Engine (J623-CDUC) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0003
Revision: 53H37---
Coding: 1A25401A057601020000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TDI0114G0907401F 001003
ROD: EV_ECM30TDI0114G0907401F.rod
VCID: 2643439F59E704BB99-8072
3 Faults Found:
5211 - Fuel Rail/System Pressure
P0087 00 [232] - Too Low
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 5
Mileage: 237887 km
Date: 2021.05.29
Time: 11:23:54
Engine RPM: 1875.50 /min
Normed load value: 85.1 %
Vehicle speed: 98 km/h
Coolant temperature: 88 °C
Intake air temperature: 24 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.340 V
Unlearning counter according OBD: 40
Fuel temperature: 29.2 °C
Mean injection quantity: 55.88 mg/stroke
Rail pressure regulation: status-Bits 0-7: 5
Fuel high-pressure: actual value: 1.3e+006 hPa
High fuel pressure: specified value: 1.8e+006 hPa
Pressure control valve adaptation factor: 1.0585
Fuel level: 51.00 l
5212 - Fuel Rail/System Pressure
P0087 00 [096] - Too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 237906 km
Date: 2021.05.29
Time: 12:08:30
Engine RPM: 2079.50 /min
Normed load value: 99.6 %
Vehicle speed: 85 km/h
VCDS
Self-Diagnosis Log
Page 4
Coolant temperature: 89 °C
Intake air temperature: 33 °C
Voltage terminal 30: 13.740 V
Fuel temperature: 17.6 °C
Mean injection quantity: 51.55 mg/stroke
Fuel high-pressure: actual value: 975000 hPa
High fuel pressure: specified value: 1.2347e+006 hPa
Fuel level: 49.00 l
14587 - Cylinder 5 Glow Plug Circuit (Q14)
P0675 00 [101] - Electrical Fault
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 237880 km
Date: 2021.05.29
Time: 11:02:28
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 14 °C
Intake air temperature: 14 °C
Voltage terminal 30: 11.060 V
Glow-control unit: activation voltage: 10520 mV
Glow_period_control_unit_ground_offset_voltage: -320 mV
Glow-control unit: calculated glow voltage: 11430 mV
Glow_period_control_unit_energy_integrator_calculated_value: 125.5 V²s
Glow cycles upon reaching temperature threshold-Bits 0-7: 0
Glow cycles upon reaching temperature threshold-Bits 0-7: 18
Glow status-Bits 0-7: 0
Co EOM st Op Mode Short-Bits 0-7: 8
Readiness: 1 1 0 0 0
VCDS
Self-Diagnosis Log
Page 5
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G2 927 156 H HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H08 0002
Revision: --H08--- Serial number: 0000000880
Coding: 000001
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDL501021 A03005
ROD: EV_TCMDL501021_A03.rod
VCID: 3365AACB9A3561130E-8066
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 B HW: 4G0 907 379 B
Component: ESP PREMIUM H09 0190
Revision: -------- Serial number: --------------
Coding: 27A6C702E465E340EB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 003013
ROD: EV_ESPPremiAU57X_003.rod
VCID: 306FA5C76B235A0B73-8064
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 AP HW: 4H0 907 064 AP
Component: BCM2 2.0 H24 0217
Revision: 00002001
Coding: 05AA2F00000000000000
VCID: 77FD5EDBC6CD4D33F2-8022
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000094537015
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4G8 959 760 C HW: 4G8 959 760 C
Component: MEM-BFS H04 0153
Revision: AA000000 Serial number: 00000006093283
Coding: C018320085006201010001010101112030303333283333
VCID: 3A7B87EFB55F905BCD-806E
VCDS
Self-Diagnosis Log
Page 6
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 L HW: 4G0 820 043 L
Component: KLIMA 4 ZONEN H11 0056
Serial number: 03051100040348
Coding: 361300BE04
ASAM Dataset: EV_AirCondiComfoUDS 002029
ROD: EV_AirCondiComfoUDS_002.rod
VCID: 285F4DA753F312CBAB-807C
VCDS
Self-Diagnosis Log
Page 7
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 G HW: 4H0 907 063
Component: BCM1 2.0 H12 0092
Revision: 11012002 Serial number: 00000001052809
Coding: 0D07A01009769FE089810080A0001800CF9CE3082E090101000308452F00
VCID: 2C57B1B74F0B3EEB4F-8078
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 110428 H35 0051
Serial number: 110430091240
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11418707
Coding: 025C55
Subsystem 3 - Part No SW: 4G0 941 531 F HW: 4G0 941 531 F
Component: E1 - LDS H07 0044
Serial number: 11 04 2011 00000004
Subsystem 4 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A31 LED Mod1L H02 0001
Serial number: 00000000001104041550
Subsystem 5 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A27 LED Mod1R H02 0001
Serial number: 00000000001104041564
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 2F2884A5000000000001
Subsystem 7 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A32 LED Mod2L H02 0001
Serial number: 00000000001104041729
Subsystem 8 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A28 LED Mod2R H02 0001
Serial number: 00000000001104042682
VCDS
Self-Diagnosis Log
Page 8
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 E HW: 4H0 035 108
Component: DVDCAlpine H42 0190
Revision: AA001001
Coding: 010000
VCID: 224B5F8F3DCFF89BF5-8076
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 H HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0030
Revision: 11001001 Serial number: 55901108100017
Coding: 312B03
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000_001.rod
VCID: 377D9EDB8E4D8D3332-8062
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 HW: 4G0 907 561
Component: ACC3 H19 0160
Serial number: 00000000000000
Coding: 3F04010201
Shop #: WSC 54573 000 1048576
ASAM Dataset: EV_AdaptCruisContrAU57X 001003
ROD: EV_AdaptCruisContrAU57X_001.rod
VCID: 67DD0E9B9E6DDDB362-8032
VCDS
Self-Diagnosis Log
Page 9
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG002BHN5
Coding: 30314530323130303038554A304C34473853
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 366393DF8947743B29-8062
Crash sensor for side airbag: driver side:
Serial number: 3575HRB404V0H0LUAPPR
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585HRB404V0H0LU4OOK
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515JRB405P0H4DUA19H
Passenger side rear thorax airbag crash sensor:
Serial number: 3525JRB405D0G9449PK9
Crash sensor for front airbag: driver side:
Serial number: 3554VRB405D0GR36KH5U
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB405J0GR36B9DS
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H03 0003
Revision: -------- Serial number: 90372KDR0006Z
Coding: 0000FC
VCID: 377D9EDB864D8D3332-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H07 0009
Serial number: 18 03 2011 11119406
VCDS
Self-Diagnosis Log
Page 10
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 931 HW: 4G8 920 931
Component: TDieRdwAccNv H34 0312
Revision: 19100074 Serial number: 658190411593030
Coding: 138701025F070008000100
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K_AU57.rod
VCID: 6BD572AB8285F9D306-803E
Address 18: Aux. Heat
Cannot be reached
VCDS
Self-Diagnosis Log
Page 11
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G0 907 468 C HW: 4G0 907 468 A
Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000142734
Coding: 00CD077D00
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650386466
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 11125001096011200410
2 Faults Found:
12290 - Quiescent Current
U1406 00 [008] - Too High
Freeze Frame:
Fault Priority: 7
Fault Frequency: 17
Reset counter: 110
Mileage: 237603 km
Date: 2021.05.23
Time: 18:39:21
Voltage terminal 30: 12.5 V
Voltage terminal 15: 0.0 V
Control Module temperature: 20 °C
System status: LIN_active
IN ESP_standstill flag: no standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
12291 - Energy Management Active
U140B 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
VCDS
Self-Diagnosis Log
Page 12
Reset counter: 110
Mileage: 237603 km
Date: 2021.05.23
Time: 21:42:36
Control Module temperature: 17 °C
System status: Awake_Timer_active
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 1
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
Component: FLA H04 0004
Revision: AA001002
Coding: 04018E646E6E645A5A253D3E
VCID: 3365AACB923561130E-8066
VCDS
Self-Diagnosis Log
Page 13
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 D HW: 4G0 919 158 D
Component: KLIMA FOND H07 0056
Serial number: 20041100040064
Coding: 01
ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
ROD: EV_ClimaContrUnitRearUDS_002.rod
1 Fault Found:
0033 - Motor for Rear Right Upper Body Vent
B10D4 22 [008] - Signal Amplitude Too High
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 110
Mileage: 237875 km
Date: 2021.05.28
Time: 19:14:59
Voltage terminal 30: 11.56 V
Outside temperature: 21.5 °C
Right Rear Upper Body Vent Motor-Act.val.: 11085
Right Rear Upper Body Vent Motor-Target value: 11085
Right Rear Upper Body Vent Motor-Stop open: 11400
Right Rear Upper Body Vent Motor-Stop closed: 10000
VCDS
Self-Diagnosis Log
Page 14
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 B HW: 4G0 907 553
Component: LUFE-DAEMPFER H17 0778
Coding: 008003
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_VW51.rod
VCID: 2A5BB7AF4DFF20DBBD-807E
2 Faults Found:
405256 - Pressure Accumulator for Level Control
C11AF F0 [008] - Leak Detected
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 111
Mileage: 237878 km
Date: 2021.05.28
Time: 19:20:03
0086 - Terminal 15
U1405 00 [009] - Implausible signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 71
Mileage: 237875 km
Date: 2021.05.28
Time: 19:10:50
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H04 0153
Revision: AA000000 Serial number: 00000006093286
Coding: C0183B0085016201010001010101112030303333203333
VCDS
Self-Diagnosis Log
Page 15
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4200U7TN0
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D51BCB37C1137E358-8078
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 H HW: 4G0 907 566
Component: J769 SWA MasterH01 0010
Revision: 00H01000 Serial number: 6PZ 010 287-02
Coding: 0010103
VCID: 3467A9D7573B662B17-8060
Subsystem 1 - Part No: 4G0 907 568 H
Component: J770 SWA Slave H01 0010
Subsystem 2 - Serial number: 6PZ 010 287-22
Subsystem 3 - Serial number: 5F27.04.1100H010003C721728ÿ
Subsystem 4 - Serial number: 721728ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 B HW: 4G8 959 793
Component: TSG FA H04 0210
Coding: 011F56235E00628202080003
Shop #: WSC 02312 785 00200
VCID: 3F8DF6FBAE7DB573FA-806A
VCDS
Self-Diagnosis Log
Page 16
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H33 0010
Revision: 00001000 Serial number: 0010073354
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326BAFCF652F681B05-8066
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0149426671
Coding: 01000E2020B9B48183200A842C0100000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00000268553
Coding: 010000
Subsystem 2 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H09 0027
Serial number: WA101432000000272537
Address 47: Sound System (J525) Labels: None
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007000 Serial number: 00000000033817
Coding: 030000
Shop #: WSC 38730 001 1048576
VCID: 1D316C7304B1C763C8-8048
VCDS
Self-Diagnosis Log
Tuesday,01,June,2021,12:31:32:00009
Page 17
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 C HW: 4G8 959 792 A
Component: TSG BF H04 0210
Coding: 011F56235E00628202080002
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000070300
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_VW51.rod
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 110505-0004-073
Coding: 11236F601002A300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic_AU21.rod
VCID: 2C57B1B7470B3EEB4F-8078
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 053 E HW: 4G0 035 053
Component: Radio U Basic H52 0093
Revision: AB001007 Serial number: 050DK0B7556001
Coding: 010003010000000001
VCID: 204F558733C3EA8BE3-8074
VCDS
Self-Diagnosis Log
Page 18
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 670 G HW: 4G0 035 670
Component: H-BNT-EU H46 0484
Revision: -------- Serial number: 428E-0B7514257
Coding: 090100040003FBEF7D34EB3E00000003080001000000000000
VCID: 275D4E9B56ED1DB3A2-8072
Subsystem 1 - Part No: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB1300QBQ.
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 612 L
Component: E380 BDT C7 H08 0204
Serial number: 90349KDR0001M
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 C HW: 4G8 959 795 A
Component: TSG HL H03 0210
Coding: 010F14234000628202080002
VCID: 428BFF0FDD8FD89B95-8016
Address 69: Trailer (J345) Labels:. 4G8-907-383-V1.clb
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Anhaenger H09 0100
Revision: 5G001001 Serial number: 00000149432496
Coding: 0109080000000000
VCID: 71E960C3A8A913033C-8024
VCDS
Self-Diagnosis Log
Page 19
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0050
Revision: --H04--- Serial number: 525 PA8J14F028
Coding: 1030013
VCID: 25414493ECE10FA390-8070
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G8 959 107 D HW: 4G8 959 107
Component: HDSG-Modul H12 0036
Revision: 11012001 Serial number: 105100655
Coding: 0A3205C001
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0210
VCDS
Self-Diagnosis Log
Page 20
Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
Part No SW: 4H0 907 547 E HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0026
Serial number: 0K84AE40032354
Coding: 1401
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
VCID: 3169A0C3602953037C-8064
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H09 0008
Serial number: 00000000001417400046
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H24 0034
Revision: -------- Serial number: 262130025421000
Coding: EA060000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 65C104936461CFA350-8030
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00000171259302
Coding: 766FF2
ASAM Dataset: EV_IVBDriveSideFrnt 001003
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F6DA6BB761D45F36A-807A
VCDS
Self-Diagnosis Log
Page 21
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00000171261201
Coding: 366FF2
ASAM Dataset: EV_IVBPasseSideFrnt 001003
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 HW: 4G0 907 541
Component: ACC3 H15 0160
Coding: 3F04010201
ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
ROD: EV_AdaptCruisContr2AU57X_001.rod
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 B HW: 4H0 907 107
Component: BV-SG H29 0034
Serial number: 000040182204117
Coding: 03C0BB1C1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 2541449324E10FA390-8070
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FED66BBB69D05F32A-803A
VCDS
Self-Diagnosis Log
Page 22
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70EF65C7ABA31A0B33-8024
End-------------------------(Elapsed Time: 12:02)--------------------------
