Oil warning light
moggie93
South Lanarkshire
Hi all. On my way home from work this morning I had a yellow oil can come up on my dash display saying sensor.
I immediately stopped and checked the oil level which was fine.
Anyone any ideas as to the cause of this ?.
thanks M
if the levels ok it would just mean you have a faulty oil level sensor, just keep an eye on it and swap out the sensor on the next oil change
nothing to worry about !
Thanks boomtown, I'll get one ASAP. I'm nearly due an oil change, so ill do it sooner rather than later. Might even pop into ECP tomorrow as I also think I need a brake light switch.
m
Hi doodah, I got one at ECP but as they don't list it on their website I couldn't get discount. But I got the 25% off everything else. Still spent over £120 on parts..
m
Bummer! At least you got discount on the other bits you needed though :yes:
Make sure you get the right one, look under the car the possibilities are two identical part numbers, the last digit is 'B' or 'C' pretty sure tha a ones are pre-b6, the 'C' one has a C in the cooling fins/casting, the B one does not.
got mine off eBay for about £28 posted.
