P 2002 Help Needed...
Omergnl
Manchester
Hi everyone,
The error code keeps popping up, whats your thoughts?
DPF regeneration? EGR cooler full? O2\Lambda sensor fault? Throttle body?
Please kindly advise. Error code as follows:
1 Fault Found: 19226 - Particulate Trap Bank 1 P2002 00 [237] - Efficiency Below Threshold MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 3 Mileage: 100325 km Date: 2021.05.25 Time: 20:28:49 Engine speed: 1332.50 /min Normed load value: 66.3 % Vehicle speed: 36 km/h Coolant temperature: 87 °C Intake air temperature: 54 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 13.040 V Unlearning counter according OBD: 40 Exhaust mass flow of low-pressure EGR: calculated: 3.519 Differential pressure ratio: low-pressure EGR: 27.9 kg/h Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 59.0 hPa Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 56.5 hPa Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 86.60 % Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 40.56 % Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 56.3 hPa Readiness: 1 1 0 0 0
Hi everyone,
Egr cooler.
Hi everyone,
Just wondering if you ever got this issue sorted and what the fix was?
Reactions: Adrian1871
605
6K
3K
801
