spudgunblunder
- Joined
- Jan 1, 2016
- Messages
- 5
- Reaction score
- 0
- Points
- 1
Hi all,
My 2009 Audi A3 8P Sportback 2.0TDI is on about 114k. Only owned for a few months.
Coil light now flashes (intermittently) on the dash and goes into limp mode. This is usually when driving the on motorway but has come on when driving at around 50mph at moderate revs (0-2500rpm).
Stopping and turning ignition on and off resets it untill you get back up to speed or maybe a few miles down the road.
Code reading gives the following:
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 7
Reset counter: 255
Mileage: 183279 km
Time Indication: 0
Date: 2015.12.26
Time: 17:12:15
After a bit of research all fingers point toward a vacuum leak on the turbo actuator diaphragm.
(See Audi 2.0TDI actuator fix Fault code: P0299 under boost)
I tested the actuator by removing the rubber tube to the Charge Pressure Solenoid Valve (N75) and sucking the tube and it would not hold vacuum.
I then had a quick drive down the road and logged the boost pressure:
(After reading this: http://uk-mkivs.net/topic/34834-vnt-tdi-turbo-how-to-adjust-actuator-cure-boost-problems/)
Seems the turbo is struggling due to the actuator not moving the vanes open to spin the turbo up quickly at low revs.
Am I on the right line?
How much to get it fixed at a) Audi garage b) Local garage?
What's the chances of getting it done on the Momentum warranty that came with the car (not holding my breath)?
Is it accurate enough to replace myself and setup using the original as a guide to setting the adjustment screw and fine tune by recording logs and tweeking the adjustment screw?
Thanks in advance for any help.
Spud
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 255
Mileage: 183279 km
Time Indication: 0
Date: 2015.12.26
Time: 17:12:15
Spud
