Phone prep removal and double din conversion
Thom Cottrell
Hi all,
So I should be picking up my A4 Avant 2005 2.0TDI tomorrow and it has the phone prep attached to the centre console.
I want to remove this phone prep as I have a iPhone 6 Plus and if I end up with holes after I'd like to cover them up.
I've looked on eBay and seen you can get a replacement centre console cheap'ish but how do I know if it will fit my A4? I have navigation controls on my centre console next to the hand brake, will this be problematic? And would you say this is easy to replace?
My next question is, if I replace the centre console I'd like to covert the single din to a double din but can't find a cheap bracket to do this. Is this also difficult to do?
Sorry if this is asking to much, but I hate the phone prep thing.
Reactions: phil_w
Hi good luck with your new motor as ive read you other thread i dont know about the phone cradle but doing the sigle to double is easy a bit of time is needed i have a link of how to. Youll find the part you need is cheaper from audi than second hand. the climate control you can cut down to fit or look for a cheap double din one.
First part look ok if you have arm rest or are plaining to fit second you can get from audi for a bit cheaper brand new try mike in parts request for a price.
Sent from my SM-A300FU using Tapatalk
I already have he arm rest in the car so yeah hats fine.
As for the second part I've got the double dim climate control or steady I think it's double.
I'll try the parts section for it too.
