WX51TXR
Polished Bliss
- Joined
- Mar 6, 2005
- Messages
- 1,452
- Reaction score
- 16
- Points
- 36
- Location
- AB51 0TH
- Website
- www.polishedbliss.co.uk
Another write up from Clark, originally posted on DW...
This car was done several weeks ago but only getting round to posting it now
It was only booked in for a 2 day correction as the swirls and marring were very very light so it only needed a 1 stage finishing polish (made a nice change! )
So up first was the pre-foam (Megs Hyperwash @ 60 degrees)...
Then rinsed off (you can just about see the swirling circled)...
I then cleaned the wheels and tyres with Menz 7.5 and the arches with Megs Superdegreaser before foaming the car again and washing with the 2BM and Shampoo Plus:
After rinsing i put the car inside and went straight to claying as there were no big tar spots that warranted using Tardis this time.
Meguiars Mild Detailing Clay and plain water was used for lube:
A final rinse off followed and i then dried everything off with a waffle weave and the leaf blower.
Once paint readings had been taken i then set about polishing out the minor defects - using Menzerna PO85RD and a 3M Finishing Pad @ 1500rpm's:
The side skirts and lower halves of the bumpers were pretty swirly though so i stepped up to 4" a polishing pad & 106FF for these areas:
I'd usually show a few before and after shots but in all honesty i couldnt capture much on camera and the paint was in extremely good condition prior to polishing
After a dust down to remove any polishing dust i gave the car a complete wipe down with Menzerna Top Inspection. This removed any remaining polishing oils and left the paint squeaky clean :thumb:
The Owner wanted Vintage as LSP so this was applied via a German Applicator Pad:
While this cured i detailed the interior and fed the leather with Raceglaze Leather Balm, then cleaned the Glass with Megs Glass Cleaner Concentrate.
The wheels were sealed with Poorboys Wheel Sealant and tyres dressed with Blackfire Long LAsting Tyre Gel. Tailpipes were polished up with Raceglaze's Metal Polish.
One last wipe down followed, this time with Last Touch to remove any wax holograms and then i quickly snapped a few after shots (not a huge amount though as the Owner was in a bit of a rush and i had gone over my time limit slightly)
