Problems
smartins
Leamington Spa
Bought this B6 PD130 CVT yesterday knowing about some issues with the TCU the guy obviously lied to me say he replaced the TCU and it just need to be coded. Today when plugged it in a big list of errors came up.
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 LJ
Component: 1,9l R4 EDC 0000AG 5934
Coding: 00001
Shop #: WSC 06325
VCID: 6ADB77AF167FE0D6AD-4B18
WAUZZZ8E15A112824 AUZ6Z0D0294703
2 Faults Found:
18034 - Powertrain Data Bus
P1626 - 35-00 - Missing Message from TCU
17994 - Engine Mount Solenoid Valves (N144/N145)
P1586 - 35-10 - Short to Plus - Intermittent
Readiness: 1 1 1 1 1
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E1 910 155 N HW: 01J 927 156 HT
Component: V30 01J 1.9l PD RdW 3251
Revision: 00000012 Serial number: 00000002039603
Coding: 0000001
Shop #: WSC 80093 222 69422
VCID: 3169A0C3AB29530EAC-515A
3 Faults Found:
18262 - Powertrain Data Bus
P1854 - 000 - Hardware Malfunction
Freeze Frame:
RPM: 96 /min
RPM: 0 /min
RPM: 0 /min
(no units): 1.0
Torque: -34.0 Nm
Temperature: 23.0°C
T.B. Angle: 0.0°
Bin. Bits: 0101 0 0
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller
Freeze Frame:
18260 - Powertrain Data Bus
P1852 - 000 - Implausible Message ECU
Freeze Frame:
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 4529
Coding: 04259
Shop #: WSC 06435
VCID: 65C10493FF61CFAE80-513C
3 Faults Found:
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 35-00 -
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AC
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 06325
VCID: 62CB1F8FEE4FB89665-5178
2 Faults Found:
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 981 C
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00401
Shop #: WSC 00006
VCID: 2D51BCB3E71137EE88-5178
1 Fault Found:
01315 - Transmission Control Module
49-00 - No Communications
Anyone can point me in the right direction where to start?
