Hi all,
I noticed on the drive back the air con would not switch on.
It is on when starting the car but then flips to off and the other options are greyed out.
Scanned for codes and I get the following:
VCDS:
262914 - High Pressure Sensor
B10AE 21 [008] - Signal Amplitude Too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 31
Reset counter: 89
Mileage: 51811 km
Date: 2020.05.12
Time: 14:01:58
Outside temperature: 13.50 °C
Engine RPM: 1490 /min
Compressor current: actual value: 0.00 A
Temperature downstream of evaporator: 18.50 °C
OBD11:
Lower limit not reached
Fault Code: B10AE21
I ran a Refrigerant Pressure Test and it came back with 0.80 bar (unsure if this is good or bad)
It might be a regas and thats it or is this model also popular with the ol' rock hitting compressor?
Have got it booked in with Audi however I'm in limbo at the moment because of the Christmas break - Curios to see if anyone has seen this before?
Thanks in advance
VCDS:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 31
Reset counter: 89
Mileage: 51811 km
Date: 2020.05.12
Time: 14:01:58
OBD11:
Fault Code: B10AE21
Thanks in advance
