Q7 major servicing at 79000 whats involved
quattro25years
DORSET
Hi,
going to book my q7'in for a major service(on long life)
(just passed its MOT with no advisories)
I had a look at the service book, as far as I can see the following is needed.
DUST and POLLEN filter
OIL/ OIL FILTER change using long life oil
FUEL FILTER changed .
Inspection
Have I missed anything that needs to be changed ?
thanks in advance
Many thanks for reply
Mine is Chain driven,
i thought all q7s were chain drive?
best
quattro25years
if its like the A6 3.0's it may need the injection pump belt changing.
I really wouldn't carry on with long life servicing ...
Especially as you have:-
model is 3.0 tdi s-line on a 56 plate.
Your engine is timing chains, 4 in total, they are located at the back of the engine. Do a google for SSP327_Audi engines - Chain drives there are two parts to file (first 2 hits in google).
With long interval oil changes the chains can stretch and tensioners wear quicker and chain rattle can occur (do a google for V6 TDI chain rattle). It's then engine and gearbox out to to change all and bill is not cheap!
There are other reasons as well to avoid LL servicing perhaps have a google ...
As Gup says, ditch the longlife, more than likely your oil has been in there since 59k-ish.
My A6 is on fixed which is 10k/1 year. Hopefully the bits I've had done between 59k and 79k will give you an insight to whats needed.
63k
63kService_zps64b0946c.jpg~original
74k
82k
Some handy PDF's for Q7 owners, get your google googles on :D ...
SSP 361 Audi Q7
SSP 362 Audi Q7 - Running Gear
SSP 363 Audi Q7 - Power Transmission
SSP 364 Audi Q7 - Electrics
SSP 375 Audi Q7 - New Driver Assistance Systems
And for the context of the V6 3.0 TDi
SSP350 The 3.0l V6 TDI engine
SSP351 The common rail fuel injection system fitted in the 3.0l V6 TDI engine
Hi
many thanks to ALL of you for the info -lots to read - excellent!
A6chris- thanks for taking the time to scan/upload your service invoices
quattro25years
Reactions: gupsterg
Hi
quattro25years
No problem - not sure if they helped or not!
Read the ssp docs Gup posted, they're a good read to the insight of the depths of your car if you have a few mins to browse.
Reactions: gupsterg
