Q7 Q7 traction control ABS light
MeeMee84
London
Good evening all, currently have an 2007 Audi Q7, randomly when accelerating traction control and abs light comes for a few seconds and car loose power and then car goes back to normal, can’t find any fault codes about ABS as the light don’t stay on for that long how ever getting this code on the screen when I got it diagnosed error code 53255 any one else experience this problem? Would like some input thank you, I’ve attached a screenshot of error code.
Does the speedo turn of & all lights functions die also?
I would say if so, check battery terminals for any corrosion, clean up with a dremel or sandpaper, see if that helps.
Thanks the seepdo and all lights don’t die. I’ve cleaned the battery terminal and tested same problem, I’m thinking maybe ABS pump? But no code on machine still also notice light smoke coming from the front wheels which is not normal.
