Hi all,
I have a TTS 8j 2011 equipped with RNSE 193d, graphic OPS for front and rear sensors, KUFATEC IMA BASIC PLUS and moving images release; I just bought the RVC r8 module with the final A (in order to integrate the camera to the OPS graphics) and I'm trying to make the RVC—> RNSE and IMA BASIC PLUS—> RVC wiring; for the first we are there but for the second I would like to confirm that it was correct as I am doing;
1) I'm modifying my current IMA BASIC PLUS wiring, I move the PINs from the gray T32b socket to the T54 of the RVC module as follows:
T32b 31—> T54 11
T32b 15—> T54 13
T32b 32—> T54 15
T32b 16—> T54 17
T32b 30—> T54 18
2) the PINs T32b 13, 28, 29 can I leave them at the gray socket or should I move them to the T54?
3) I want to try to make the RVC r8 system work with an aftermarket camera which, however, is powered at 12v and instead from the T54 48 PIN, a voltage of 6v arrives; how did you solve it, what resistance can I insert between the t54 47 and t54 48 PINs to make the circuit work and not give an error or have you powered the camera from the two PINs above and added a 6v—> 12v converter?
