Hi, relatively new here so hi everyone...
I was driving home from work yesterday and I noticed the air con wasn't cool, it then started making a hissing noise and stopped. It put it's self into econ mode and pressing the button wouldn't do anything.
As soon as I got home I scanned it on VCDS and got error codes for both the cooling fans saying movement restricted or jammed.
I manually checked both fans, they both move freely, but both have a slight wobble. I reset and the codes didn't come back, the air con also started working again. I assume the air con disabled it's self because of the fan fault?
The car is an 03 with 117k on it. I have had the same error codes for the fans in the past and they have always cleared, are they on the way out? Temp gauge always warms up normally and never goes about half way.
I also got a 02071 local databus which I don't know anything out and haven't seen before, should I be worried about that?
Cheers in advance for any help!
