Rain sensors help
Daniela3
Hi there does any one know the difference between 8U0955559b & 8U0955559C. As when I spoke to Audi they said 8U0955559B has been replaced with 8U0955559C. So I have brought the C version but it keeps saying controls module incorrectly coded my vehicle is 2015 am I going to need the B version ? i have log if required
Any help would really be appreciated
thanks
NHN
Site Sponsor
Retrofitted or replacing faulty?
Daniela3
Car is 65 reg A3 saloon I purchased
8V0941531L
8U0955559C
A local chap tried to code it multiple times but keeps coming up incorrectly coded module, im not sure if he is doing it incorrectly but showed him multiple differnt codings from this forum and still does not work although the auto lights has appeared in the mmi ‍♂️
Dan
Daniela3
Hi all can confirm after fitting the above and had it programmed with vcds it is now working as it should. 8U0955559B has been replaced with 8U0955559C as Audi said it’s the same part just revised number. It has worked on my ore face lift version just info In case others need it. Thanks for everyone’s help !
Dan
