Raising rear AP Coilovers
James36
RS3 Rep :)
Wolverhampton
This morning thought I'd raise the rear end of my car, but the whole thing spins when I turn the adjuster with the spanner?
Any ideas, did the same with the front, worked a dream... why don't my rears want to adjust.
Tried gripping the black thread but can't get enough on it to stop it spinning.
Drop the trailing arm, its 1 bolt, remove spring, then adjust, refit.
Reactions: James36
Thank you!
Is it the bolt I've circled in the attachment? (Sorry zero mechanical knowledge I just love having a go)
No, its the other end of the arm attached to the brake side so to speak, use a jack under the arm to take tension of the bolt to undo & remove easily, when refitting again jack the arm up to refit bolt & tighten, releasing the jack when nearly fully tightened, best to tighten 100% when its under load, as in wheel on ground or sat on bricks, wood, mini ramp on that corner so you can get underneath to tighten as its awkward & must be to torque given its importance.
Reactions: James36 and ch1z64
Made sense, thank you...
Got it straight back on stands, even with the arm jacked up I couldn't release the bolt either side, proper tight and rusted on, bit gutted seemed easy enough. And spent a good hour or so trying.
I clocked my drivers rear wheel is sticking out a touch further than the other side, so may have a camber or alignment issue. I'll book it to get adjusted atleast it should be easier to release if I want to alter again, and this wheel sorted...
Thanks again bud!
Wd40, let it stand then with breaker bar or a gun, should be able to loosen.
3K
667
9
5K
N8
8K
