Random 'SAFE' message on dash clock
max69vk
Kingston upon Thames
Got into the car this morning & drive to work but for some reason the windows wouldn't go down, also when I looked at the dash the date in the speedo display wasn't there & was displaying 'SAFE' (see pic below). I pulled the car over turned it off & on & all was normal again, it has nothing to do with the radio or any other warnings as everything was 100% ok other than the windows. Bit random but any ideas what causes this? ImageUploadedByTapatalk1367318831219501
Fob battery low perhaps?
I think it still may be the radio for some reason or another though.
Weird that it would affect other things like the windows.
Have you got access to VCDS, maybe give the car a scan for any faults.
I must admit, the only time I have ever seen the word SAFE appear in my car, was on the H/U.
If VCDS comes back OK, I would presume all is OK but you can always ask Audi.
I've seen it on my dash when the keyfob wasn't programmed.
I have this safe message on the display now and the windows won't go down ! Did anyone work out what was causing this
Maybe a stupid answer but have you hit a button that locks the windows ? Lol!!
Looks like it's a key / immobilizer fault.
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Part No SW: 8P0 920 981 F HW: 8P0 920 981 F
1 Fault Found:
01176 - Key
004 - No Signal/Communication
I Had this message when i changed my clocks to different ones....
its still on there but everything works fine and car starts and drives so i just left it :) nuff respect lol
Thanks Shabs. Will check the clocks ! Do you have any other fault codes like the one I found in the Immo?
i had the following. Dont know if they are related but assuming they are:
1 Fault Found:
18058 - Powertrain Data Bus
P1650 - 000 - Missing Message from Instrument Cluster - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 354.0 Nm
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 5
Reset counter: 217
Mileage: 260150 km
Time Indication: 0
Date: 2014.12.29
Time: 00:02:20
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 P HW: 8P0 920 980 P
Component: KOMBIINSTR. VDO H71 0210
Revision: D03 Serial number: 2249DD03006422
Coding: 0004408
Shop #: WSC 00502 067 57207
VCID: 4487AA9B076E043EF0B-8011
1 Fault Found:
00668 - Supply Voltage Terminal 30
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 3
Reset counter: 225
Mileage: 261254 km
Time Indication: 0
Date: 2015.01.05
Time: 12:07:31
00381 - Databus Instrument Cluster
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 22
Reset counter: 217
Time Indication: 15
for the Immobiliser i had no fault with that:
Revision: D03 Serial number: AUX7Z0D9FN108V
Shop #: WSC 00481 210 83561
No fault code found.
Got into the car this morning & drive to work but for some reason the windows wouldn't go down, also when I looked at the dash the date in the speedo display wasn't there & was displaying 'SAFE' (see pic below). I pulled the car over turned it off & on & all was normal again, it has nothing to do with the radio or any other warnings as everything was 100% ok other than the windows. Bit random but any ideas what causes this? View attachment 14841
Hi max69vk!
Had this problem with the your Audi is solved already? I have the same problems and no one has a clue.
thx for your help
G
775
Goner
G
14
21K
842
