Rear anti roll bar recommendations?
audismart
YOU ARE JUDGED BY THE CAR YOU DRIVE.
As above for my FWD 2.0tfsi S-Line.
Just wanted to know if anyone got any experience with the rear anti sway bars for the FWD, like is it a worth while upgrade, does it improve understeer???
Boydie
S3 8V DSG
It may help a bit but will just depend on your driving style, if you are tracking the car, etc...
I had H&R on my S3 which did make a difference a long with an anti lift kit for the front.
Check out www.orange-tuning.de for prices for bars
audismart
Yeah I`m going to be fitting superpro alk with alloy arms and adjustable ball joints, just wanted to get some guidance on how stiff to make the rear to reduce under-steer on the fwd, difficult to get a guide on the Haldex setup as its totally a different driving experience due to weight and power transfer.
Thanks for your input though.
kash_v
Go for H&R front and rear kit.
Set the rear to the stiffest (only two settings, stiffest is the hole nearer the bar) and set the front to soft.
If you're a talented driver set the front to stiff too.
downtothebone
I'm on Eibach front and rear on my sline Cabrio ....
audismart
LOL, if its stiff all over sounds like it will be a skittish sort of drive, I was thinking of a staying on the standard roll bar on the front with powerflex bushes and a thicker roll bar on the rear?
audismart
downtothebone
yeah I was thinking along the lines of eibach, did you find a big difference?
The reality is you can't really go wrong with any of the established brands - I was originally going with H&R but as I was also doing the fronts the Eibach front comes with the bracket preinstalled so saves on the labour cost ...
