Facelift Rear parking sensors - Volume increase
airbus319
Well-Known Member
Glasgow
Hi,
Does anyone know if it is possible to increase the volume of the rear parking sensor unit using vcds?
It's already at max on the MMI
thanks
David.
Hi,
thanks
David.
Depending on your control module there are settings which look like they might do something. Would need to test though as I have never had a reason to play with these.
Screenshot 2019 02 21 at 182821
Reactions: airbus319
DJ Alix thanks for your response, it's my partner's car, my PFL car is about 75% louder than hers which is terribly quiet. There's nothing wrong with my hearing thanks.
I'll fire up VCDS on it later and see what I can find.
David.
David.
Might be a faulty buzzer / speaker then. The parking sensor has one in the front and in the rear. Might be some padding covering it?
David.
Hi
I have the same exact issue, did you manage to solve it via VCDS?
