Hi.
I have a A3 8V FL with rear PDC, and wanted to install rear view camera.
I bought the camera from Kufatec, so I coded everything with a coding dongle I got from them.
The camera wouldn't work, but I read somewhere that I had to set "Car_Function_List_BAP_Gen2-parking_assist_0x0A" to not activated in 5F. And when I did that, the camera was working.
But the issue I have now is that the entertainment volume is not lowering when I put the car in reverse, as it did before I installed the camera. The audio lowering did work before I installed the camera, but stopped working when I installed the camera, so "Car_Function_List_BAP_Gen2-parking_assist_0x0A" to not activated is not the reason. I have tried to set it to activated again, without any audio lowering. I am also missing the meny for the PDC in the car menu of the MMI. The PDC is working, but I want the audio lowering to work as well.
Is it not possible to have both the camera and the PDC to work as it should with the MMI?
Adaptions in 5F:
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ,60
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15 ,8
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,not activated ,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15 ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Terminal 15 ,64
Adaptions in 5F:
