Rear wiper
Flosman
Rear wiper motor on its way out any suggestions shall I remove it completely or replace? How hard of a job isit thanks
Easy job, hardest part is getting the wiper arm off, some have been known to damage the screen if not using a puller which is about a tenner and well worth it if the arm is stuck ( Check first as it might pull off easily). New ones from Staff or Crew Audi crew about £80. Don't leave it though as eventually the water will leak out of the motor or blow the pipe off and get into the boot and lock etc.
Reactions: Flosman
My first mod was to take the rear wiper off makes the back look a little more near and tidy imo. The wiper arm itself is hard to remove it needs a soak in wd40 and the boot liner needs a good pull almost feels like your going to break the clips but you won’t
Reactions: Flosman
Cheers think I’ll give this a go Tommrow
Easy to change, you can buy OE motors on eBay . Use penetrating oil and a smaller puller to remove arm.
Cheers mate just in the middle ov it now it is a **** to get off
Smear the new motor spindle with copper grease, makes things easier in the future.
All done ended up sawing it off nice & clean finish thanks again
Should of got a kill all wipers kit rather than a grommet from halfords
600
9
875
519
NHN
726
938
