Remap & Exhaust options?
bobby_s3
Hi,
Looking to get my RS3 remapped, and at the same time both cats removed. Anyone had this done?
Can you recommend any combinations of brands and companies to do the remap? I have looked into it and APR sounds like a good choice among RS3 owners. A friend of mine mentioned Unicorn in Manchester? Anyone had any dealings?
45bvtc
The Older I Get The Better I Was
Supporter
Gold Supporter
Lots here have secondary cat by-pass pipes and many times discussed remap with the 8P RS3; do a search within the forum and I'm sure lots will be revealed.
I run secondary cat by-pass pipes and have done for 5-years or more: I've also fitted both Milltek and Scorpion to RS3s belonging to others and in truth there's little difference in either - just hollow tubes and so the outlet noise is similar.
See: "Fitting Secondary De Cat Pipes" here in this Forum
Not sure anyone has gone for 20-inch rims mind, or 9J TT rims on an 8P RS3.
bobby_s3
Cheers for the reply. I understand the secondary cat by pass, but I wanted to know about the double cat by pass? Has anyone done that and what options are available.
Regarding the alloys, am I right in thinking there was an option for 8.5j alloys on the rs3?
Sent from my SM-G925F using Tapatalk
45bvtc
Supporter
Gold Supporter
There are THREE catalytic converters on the RS3, one primary and two secondary. As you say you understand the "double cat by pass", those are the secondaries; and yes, some have indeed 'gutted' the primary cat. See Milltek catalogue for details of SSXAU344 or on eBay:
Note: actual emissions of an RS3 with secondary catalyitic converter by-pass pipes remains within UK 'legal' limits - as tested by Audi on my own car @ 0.02% difference with and without.
As for the 8.5J optional FRONT alloys; yes they are available and YES I use 8.5J rims (Audi Part No: 8P0601025CM) on my own 8P RS3 with 255/30 tyres (MPSS) and 235/35 MPSS on 8J rims at the rear.
bobby_s3
Ah great, that's the info I was looking for. I will defo look into that. Regarding your earlier post, you said you have worked with scorpion and miltek. Is there a preference?
I'm looking to lower my car using H+R 20mm springs, as budget doesn't allow for coilovers yet. So I thought might be a good time to look for some alloys to make it sit slightly better.
45bvtc
Supporter
Gold Supporter
CAUTION: you may need to look at 'twisted and/or broken propshafts" on the 8P RS3 as this has happened on more than one re-mapped car, STD ones too, when using 'launch' too often:
Just sayin'
45bvtc
Supporter
Gold Supporter
Thanks for the info. I was looking to get the uprated arp propshaft bolts fitted.
Yes you should, though I haven't; but be aware that the propshaft itself has also failed in some instances and not just the rear coupling:
And there's more than one coupling and more than one set of bolts...
45bvtc
Supporter
Gold Supporter
Both the same really. But Scorpion have stainless steel flanges and are generally cheaper than Milltek.
Nope, no preference but I've Milltek:
45bvtc
Supporter
Gold Supporter
I hear you looking at modification but for sure if I were doing any again I'd be doing the rear ARB first:
Makes a huge and +TVE difference to both handling and, in my own view, ride... :racer:
