Following all the guides on here to fit into my 2007.5 S3
Has BOSE Factory, Ipod Adapter, Bluetooth and obviously MF Steering Wheel. Fitted with a Symphony II+.
The cable from the Ipod Adapter that goes into the quadlock (blue) is one of 2. The secondary one which has no ipod adapter connected to it has different cables/amount of cables and colours in order.
Can someone shed some light, from what i should be doing as i am having the following errors;
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Control Module Part Number: 8P0 035 192 Q HW: 8P0 035 192 Q
Component and/or Version: RNS-E HIGH EU H76 0650
Software Coding: 0209715
Work Shop Code: WSC 00476 211 88564
VCID: 3D7A3BAA5B2BB8F4
5 Faults Found
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 224
Mileage: 69430 km
Time Indication: 0
Date: 2011.11.12
Time: 10:25:58
Freeze Frame
Mileage: 69430 km
Count: 1211
Clock: 10:25
00878 - Connection to Speaker Front Left
011 - Open Circuit
Freeze Frame
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 224
Mileage: 69430 km
Time Indication: 0
Date: 2011.11.12
Time: 10:26:24
00879 - Connection to Speaker Front Right
011 - Open Circuit
Freeze Frame
Fault Priority: 5
Fault Frequency: 1
Reset counter: 224
Mileage: 69430 km
Time Indication: 0
Date: 2011.11.12
Time: 10:26:24
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 224
Mileage: 69430 km
Time Indication: 0
Date: 2011.11.12
Time: 10:25:59
02005 - Coding Pin
004 - No Signal/Communication
Freeze Frame
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 224
Mileage: 69430 km
Time Indication: 0
Date: 2011.11.12
Time: 10:25:58
Plug Pictures below;
Coding is 020915 and 11422 for the bluetooth. Sound works fine except i can adjust bass/treble/mid so not sure if that is normal for the RNS-E for BOSE. The bluetooth works fine, on dash as well as music on dash.
Connect the IPOD connector to the iphone and only right side speakers work.
So putting this all aside, i thought i would try the other cable into the quadlock instead and swap the "BROWN" Cable for bose as mentioned in all the Retrofits and try that one into the quadlock. No errors except for the usual ZF error itself. Worked fine.
clearly means something is not quite right from the ipod adapter-> other plug as there is no brown cable for one as well as the errors i am getting.
Does this make sense? haha.
Any help would be muchly appreciated. As everything seems to work fine except ipod connectivity to 1 side of the car only and errors above.
Anyone know what colour on the actual LOOM is what?
Do i need a different ipod adapter (part #8E0 051 444L) for the rns-e from the symphony ii+?
Plug 1; from iPod Adapter to quadlock.
Plug 2 same as found in retrofit instructions; Other oem blue plug for quadlock (sitting lose obviously not being used as no ipod integration is in this.
iPod Adapter.
5 Faults Found
Freeze Frame
Fault Priority: 5
Fault Frequency: 1
Reset counter: 224
Mileage: 69430 km
Time Indication: 0
Date: 2011.11.12
Time: 10:25:58
Freeze Frame
Mileage: 69430 km
Count: 1211
Clock: 10:25
011 - Open Circuit
Freeze Frame
Fault Priority: 5
Fault Frequency: 1
Reset counter: 224
Mileage: 69430 km
Time Indication: 0
Date: 2011.11.12
Time: 10:26:24
011 - Open Circuit
Freeze Frame
Fault Priority: 5
Fault Frequency: 1
Reset counter: 224
Mileage: 69430 km
Time Indication: 0
Date: 2011.11.12
Time: 10:26:24
000 - -
Freeze Frame
Fault Priority: 7
Fault Frequency: 1
Reset counter: 224
Mileage: 69430 km
Time Indication: 0
Date: 2011.11.12
Time: 10:25:59
02005 - Coding Pin
Freeze Frame
Fault Priority: 5
Fault Frequency: 1
Reset counter: 224
Mileage: 69430 km
Time Indication: 0
Date: 2011.11.12
Time: 10:25:58
iPod Adapter.
