RNS-E Retrofit Fakra/ISO Adapter Question
Omy193
Birmingham, UK
Evening all,
I've just gathered all the parts to go from Symphony to RNS-E
However I've noticed my aerial/fakra adapter only has 1 connection (image attached)
When looking upon a few other RNS-E retrofits I have noticed a different adapter being used which allow for both the iso aerial to be connected as well as the yellow fakra connector (image attached)
My question is:
If I only connect the black iso aerial connector and leave the yellow fakra, will my radio have poor reception or will it not work at all?
Thank you
S l1600
IMG 0214
If yours is a symphony 2+ quadlock, you won't need an adapter, however the antenna system will be different as in reception will be degraded, if it's an ISO connection, you will need the adapter & you fit the existing biege/light brown connector into the spare slot of the adapter & the antenna system is fully compatible with the rns-e.
Reactions: Charlie Farley and Omy193
Unfortunately mine isn’t the Symphony 2+ so definitely need the quadlock adapter
Quite surprised it never came with the
RNS-E as standard (06 B7 RS4)
Ah right makes sense now
So one adapter is literally plug n play where as the other (the 1 i have) just requires the yellow fakra connector to be fitted into spare slot.
thanks for that @NHN
Fitted the RNS-E unit today
All working well
Wanted to update firmware and maps to latest version but disc wouldn’t eject, Iv come across this before in an Audi A6 where you have to manually eject via VCDS adaption channel
However issue I’m having is that vcds will not connect to modules:
37 - Navigation
OR
56 - Radio
Could this be due to a fault with the quadlock conversion harness?
Are you using latest version of VCDS, and cable? I assume you managed to Code the unit to confirm KLine is working.
Yes latest version of VCDS
Haven’t managed to code the unit as it doesn’t connect to either module unfortunately
Check your quad lock cable and make sure the Kline is connected to the correct pin,
Also try rebooting the RNS-E I guess the unit came out of Audi A4?
Is it a genuine vcds cable as some lesser kits don't allways work correctly with modules.
Yes unit came from a B7 A4
definitely genuine cable
Will try pop down to my local garage and hook up to their vcds see if that makes a difference
How would I go about checking for K-Line pin?
This is the kit i bought:
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/273339531090
Specially requested adapter for bose system and cable that arrived was labelled bose too
You need to check the cable with a tester, find the Kline pin on your Audi car loom and test the other end of the Quadlock to make
sure there is continuity between both pins.
Again, if you don't have a genuine VCDS cable you will not be able to connect to the RNS-E.
I had a third party cable that I used on my Audi B5 and it worked fine, but on the B7 it would not connect to some of the modules
like Nav, Radio, Steering Wheel etc.
I had to buy a used genuine cable.
There are install guides on the web and on forums, have you checked them out.
Sounds like you need to move the Kline to the correct PIN as thats what mine was doing before I moved it. The wiring sticker for the RNSE is on the white sticker on the top of the unit. You'll need to work out which is the KLine on the cars wirirng end. The wiring sticker on your old unit may help.
Will have a look into it next time i get a chance as the car isn’t kept where I’m staying
I also have OBDEleven so will try to see if it’ll connect through that
I thought the moving of bose/k-line pins was if the upgrading from Symphony II+ as the car would already have a quadlock connector?
The whole purpose of buying a quadlock conversion harness is for it to be plug n play, especially since there’s different harness for bose system? seller reckons he has sold hundreds of these harness kits with no issues
I shall find out lol....
Tried with my OBDEleven and connected fine
Tried my VCDS again after and connecting fine on that too now. Strange
However all coded correctly and DVD drive unlocked
Reactions: Chrismawa
481
486
749
955
