RS3 8P Help
millsy75
Hi guys, looking into buying an rs3 8p and wondered if there were any decent articles/posts for me to read up on?
I wondered if the gearbox in the 8p was the same as in the 8v? DQ500?
What are the tuning limits of the standard box and engine?
I currently have a tte470 mk7 golf r and fancy a change.
Cheers.
45bvtc
The Older I Get The Better I Was
Supporter
Gold Supporter
A 2010 Press release:
New Audi RS3 powered by 2.5-litre 340PS five-cylinder TFSI engine
Monday, November 22nd, 2010
Filed under: Audi, RS3
The revered RS badge is about to adorn a compact class Audi for the first time as the new RS 3 Sportback waits in the wings with suitably spectacular performance and an evocative five-cylinder soundtrack for a spring 2011 UK debut. The formidable yet usefully practical newcomer will be available to order in the UK from next month priced at £39,900 OTR.
Audi high performance engineering division quattro GmbH takes the five-door Sportback version of the A3 as the foundation for the latest RS model, and in deference to the classic quattros of the Eighties endows it with a turbocharged five-cylinder petrol engine that employs 21st Century TFSI turbo charging and direct injection technology.
First seen in the TT RS, this all-new unit fills the cabin with a rich, bass-heavy five-cylinder tone as it channels 340PS and 450Nm of torque to the road through a standard seven-speed S tronic twin-clutch transmission and quattro all-wheel-drive. A sound flap in the exhaust branch intensifies the sound even further when the driver presses the Sport button, which also varies throttle response.
Maximum torque is readily available at the low end of the rev range, from around 1,600 rpm, and remains constant up to 5,300 revolutions, making for excellent flexibility and response.
The large turbocharger generates up to 1.2 bar of boost pressure, and downstream of it is an intercooler which achieves an efficiency rate of more than 80 per cent. The combination of the latest forced induction technology with FSI direct injection facilitates a high compression ratio (10.0:1) along with a correspondingly high efficiency ratio. Flaps in the intake tract mix the air as it flows in. The two camshafts, each adjustable by 42 degrees of crankshaft rotation, also enhance the efficiency of the mixture formation.
As befits an RS model the impressive output of this engine is reflected in an exceptional 0-62mph sprint time of just 4.6 seconds and an electronically governed 155mph top speed. Yet less predictably, this rapidity doesn’t rule out the potential for up to 31mpg according to the combined cycle test.
Carbon fibre aids weight reduction
The efficiency of the RS 3 Sportback is due in large part to a delivery-on-demand oil pump and a regenerative system that recovers energy as the car decelerates, but is also facilitated by weight-saving measures including the use of strong but light vermicular graphite for the engine block and carbon fibre-reinforced plastic (CFRP) for the front wings. These help to keep the kerb weight of the new RS 3 down to 1,575kg, to keep CO2 output down to 212g/km and, equally importantly, to elevate the power-to-weight ratio to an impressive 216PS per tonne.
The extreme performance is gainfully employed by a chassis that lowers the RS 3 Sportback by 25mm compared with the standard A3, and comprises McPherson struts upfront and a four-link rear set-up. Balance and composure are boosted by a widened, 1,564 millimetre track, and grip by 19-inch alloy wheels shod with 235/35 series tyres at the front and 225/35 at the rear. The standard wheel finish is a machine-polished titanium look, but a black finish with red rim inserts is also available as an option.
Highly efficient electromechanical rack-and-pinion steering provides a suitably direct gear ratio of 16.2:1 for keen turn-in, while internally ventilated disc brakes measuring 370 millimetres in diameter at the front and 310 millimetres at the rear modulate speed powerfully and progressively. Their aluminium covers are encircled by four-piston fixed calipers painted a high-gloss black and bearing RS logos. To support them, the electronic stability programme (ESP) features a Sport mode that activates later intervention of the braking and acceleration retardation functions to enable greater adjustability without compromising safety. It can be switched off entirely for circuit use.
The quattro permanent all-wheel drive system oversees proceedings, granting the RS 3 Sportback an extra measure of traction, composure and stability. Its central component is an electronically controlled multi-plate clutch, mounted at the end of the propeller shaft to achieve a favourable axle load distribution. Located in its interior is a plate package bathed in oil.
Thanks to quattro, the propulsive power can be distributed to each axle as needed. Whenever slip occurs at one of the axles, an electric pump intervenes at lightning speed to increase the oil pressure. The pump presses the clutch plates together, thereby permitting the torque to be redirected accordingly. Thanks to a powerful accumulator, this process takes just a few milliseconds.
Audi RS hallmarks
The latent performance potential of the new RS 3 is conveyed subtly but unequivocally at the front end by a deeper front apron that incorporates enlarged air intakes, an anthracite coloured single-frame grille with diamond-patterned styling and xenon plus headlamps.
The side view is dominated by the flared, lightweight front wings covering 19-inch alloy wheels, prominent sill panels, mirror casings in matt aluminium look and a large roof spoiler. A high-gloss black diffuser insert and two elliptical exhaust tailpipes on the left accentuate the styling at the rear.
Inside, sports seats are upholstered in Fine Nappa leather with silver contrasting stitching, and inlays are finished in Piano black or the new Aluminium Race look. A flat-bottomed RS steering wheel and an exclusive design for the instruments and S tronic selector lever also highlight this car’s status, as does a specially configured Driver’s Information System which displays boost pressure and oil temperature and doubles as a lap timer.
The array of standard equipment also includes the Sport button, acoustic rear parking sensors, electronic climate control, DVD-based satellite navigation with MMI (Multi Media Interface) functionality and xenon plus headlights with LED daytime running lights. Optional features include front bucket seats, roof rails in matt aluminium look and styling packages in black or matt aluminium. Five exterior colours are available, plus an unlimited selection of custom paint finishes.
See:
Drove one of the first Audi 8P RS3 UK demonstrators on Wednesday 12th October 2011, bought one one of the two available on the 15th, and I still have it, and am still keeping it; I like 'em...
I've several original Sales Pricing and Specification Guides for the 8P RS3 in pdf form if you need but you'll need to PM me with your email address as I can't upload here on ASN, tsk...
Bargie1
Mine is for sale on Autotrader, red one with 53000 miles, some mods done in 2014 to bring it to just under 400 hp. Great car..
Bazgti
Bargie, did you get rid of your RS3? if so, could you inbox me the 1st 3 letters of the reg?
Ive bought an RS3 in red with just over 50k which came from Aberdeen.
Daniel Nortje
Audi RS hallmarks
See:
Hi, can't seem to PM you due to restrictions. Do you mind e-mailing me the PDF's you have for the 8P RS3?
45bvtc
Supporter
Gold Supporter
PM sent - I need your email address...
Do you want the 2010 pricing and specification guide?:
