Turning it off aside, you can adjust the settings in the mmi.Tried to kill us again yesterday. No white lines in the middle of the road but with some hatched on the left, it tried to put us in the ditch. I made a stop prior and forgot to turn off. Big mistake.
if it’s set to early it should try to correct the steering gradually, if it’s set to late it won’t do anything until you cross a line and then interact more noticeably. Obvious the faster you are travelling the more noticeable the system inputs will be.
Just read an article saying Audi had removed the option to adjust the sensitivity settings from MY22 cars in various models so it may not be there !!!Will have a look at the settings thanks. For times when I forget to disable it.
And adaptive cruise as well?I have flat bottom wheel with lane assist. Works fine.
I think I have if what you mean is a flat bottomed steering wheel with active cruise control and lane keep assist (not the thing that controls the steering wheel while you’re in cruise control, which is a shame, was it even an option on the RS3 ?)And adaptive cruise as well?
I asked Thomas from Autogufuel about the car in their latest RS3 video - it was flat bottom green alcantara and it worked with both he said.
I am wondering if the flat bottom wheel that comes with the 8Y does indeed have the sensors for capacitive control but due to some regulation Audi are not providing it with factory orders with the assistance package.
The only way to know would be for someone with a flat bottom wheel to open it up and compare it to @billymc92 steering wheel photos… Because then it would be a lot easier to retrofit. Just buy the flat bottom wheel (although anyone with the round wheel would also need a new airbag as that is a different shape).
The lane keep assist is the system that keeps you in the lane while driving whether you're using cruise or not and is what appears to push the round steering wheel. The lane departure warning is likely what you have that gives a warning and vibrates the wheel but won't actively keep you in lane and means you can have the flat bottomed steering wheel.I think I have if what you mean is a flat bottomed steering wheel with active cruise control and lane keep assist (not the thing that controls the steering wheel while you’re in cruise control, which is a shame, was it even an option on the RS3 ?)
No no, I’m well aware of what I have, here you go so you won’t have any doubt, maybe I have a problem with my car that it won’t steer itself when in cruise control when but I have lane keep assist (I know how to use it we have it in our RSQ8), and if that’s the case I need to make another trip to the dealer… I just assumed it’s not a feature on the RS3.The lane keep assist is the system that keeps you in the lane while driving whether you're using cruise or not and is what appears to push the round steering wheel. The lane departure warning is likely what you have that gives a warning and vibrates the wheel but won't actively keep you in lane and means you can have the flat bottomed steering wheel.
All that is based on what I can gather from previous posts and Facebook groups.
That's what I was trying to get at with my previous post. The button is still there on the stalk for either system but they work differently in the background.Audi seem to want to make it petty difficult to work / understand out exactly what each system does. Not sure if this a marketing ploy but systems with the same names do slightly different things in different models and can also do different things depending on what other systems are fitted to the car.
Based on what I’ve read lane departure is usually just gives warnings as abo r however if you’ve also got side assist and you signal to change lanes, it will intervene by correcting if it judges the situation to be dangerous
Maybe go into the MMI and see what options it gives you in the assistance menu. I'm pretty sure the full lane assist will give you an early/middle/late intervention option but the lane departure warning doesn't, although that could be wrong. They both have the same button on the stalk too I believe...No no, I’m well aware of what I have, here you go so you won’t have any doubt, maybe I have a problem with my car that it won’t steer itself when in cruise control when but I have lane keep assist (I know how to use it we have it in our RSQ8), and if that’s the case I need to make another trip to the dealer… I just assumed it’s not a feature on the RS3.
You are correct, but I don’t think the shape has something to do with it as the RSQ8 has a flat bottom steering wheel as well although it’s a different shape, maybe it’s something specific about the RS3 steering wheels idk it’s really weird and confusing Audi has to make it clearer, like 1 flat button steering wheel supports and the other doesn’t ? I don’t get itMaybe go into the MMI and see what options it gives you in the assistance menu. I'm pretty sure the full lane assist will give you an early/middle/late intervention option but the lane departure warning doesn't, although that could be wrong. They both have the same button on the stalk too I believe...
If it's anything like has been discussed before, it's because they weren't able / haven't bothered to add the new sensor tech into the flat bottomed ones for this generation of cars. I believe that the RSQ8 has the older sensor versions (but could be wrong) that require movement or resistance on the wheel versus the new capacitance ones that only require you to be touching it. Again, all just info I've picked up along the way so could be wrong but it's what I can piece together.You are correct, but I don’t think the shape has something to do with it as the RSQ8 has a flat bottom steering wheel as well although it’s a different shape, maybe it’s something specific about the RS3 steering wheels idk it’s really weird and confusing Audi has to make it clearer, like 1 flat button steering wheel supports and the other doesn’t ? I don’t get it
If your theory is correct and that’s the only thing that’s missing for it to work then it might be possible to code it and make it work!I have a theory that the NEW flat steering wheels do have the sensors. It has just been turned off in software due to regulations that mean they have to fit a round wheel if you want the assistance pack.
I would love someone with a flat-bottom wheel to open it up and see if there are the same sensors as the round wheel.
I don’t mind doing it thou I have no idea how to disassemble a steering wheel airbag lol
Do you have an instagram with loads of photos? Always wondered how they find the cars… now I know!Would be a good day out I suppose but I declined haha
Got Instagram but it's not loaded with car pics but yeah that's probably how they do itDo you have an instagram with loads of photos? Always wondered how they find the cars… now I know!
@billymc92 also got an invite but he’s offfshoreWould be a good day out I suppose but I declined haha
Yeah I seen that at least he was up for it I was a big no lol@billymc92 also got an invite but he’s offfshore
Having too much time on my hands today with the constant rain I’ve found a couple of articles giving a bit more detail this.I do not know, however as @billymc92 has changed the wheel he may be able to advise what to look for. Or maybe you can go to a local garage and ask them to remove the cover; I don’t think you need to remove the whole airbag as the photo billy shared showed the sensor box at the bottom of the wheel.
The actual sensor is a pad is underneath the outer layer of foam in the steering wheel rim. A separate control unit integrated into the steering wheel continuously assesses that contact and recognizes if the driver is ready to engage with traffic. The steering wheel cannot go longer than 15 seconds without being touched.
The sensor itself looks similar to this and according to the manufacturers website it can be incorporated into any existing steering wheel View attachment 254398
Yes I picked up on that a while back, car engine restarts as car in front moves away, is it done by the Camera in the rear view mirror area or the radar for the adaptive cruise?I've noticed while in traffic and the car is in start/stop mode that it can detect when the car in front starts to move off and it automatically restarts the engine. Carbon edition with ACC inactive, so not related to that feature.
I wonder, if the steering wheel has the sensor would it be possible to activate/code the active lane keep assists (the one that steers for you while in cruise control) to work ? As it’s the only thing missing for the system to workThat is an interesting find! I think the question here was does the flat bottom wheel have the sensors and the way to know is the control box as you described it at the bottom of the wheel.
That is what I am looking for on a flat bottom wheel - the control box - as that indicates it has the sensors.
Which is why someone needs to remove the airbag cover (and possibly the airbag) to check for it. As if it is there then for someone with a round wheel we can just order an RS3 flat wheel.
If it doesn't have the sensors and control box then that is different and will require either a swap like Billy did or just getting the round wheel re-trimmed.
Pugeot RCZ Asphalt Ed was the first mainstream car l saw with a matte Grey metallic paint back in 2011 anyways l do like BMWs Frozen silver but l wouldn't pay £5000 for it.....Whole panel.
I know, so gutted I’m missing it! This is just my thing! Drift mode at the ready to warm the tires before I destroy what ever I’m racing hahaYeah I seen that at least he was up for it I was a big no lol
Alcantara....Nice to look at but don't touchI have decided to get my round wheel retrimmed to Alcantara. I’m hoping to take it in next week and they will give me a “loaner” RS flat-bottom wheel for the week or so it takes to re-trim it.
Obviously, I won’t have an airbag as my car airbag is a different shape - and I’m also wondering how many warnings I am likely to get as a result of a non-connected airbag.
Any thoughts? Do we think that it might cause other systems to stop working?
Agreed ... can't say i miss the part alcantara wheel from my last RS3 or full alantara / micro-fibre from my A45.Alcantara....Nice to look at but don't touch
