Rs4 wheels on rs3
Macdaddy
Both have a PCD of 5x112 dont they?
Dont see why they wouldnt fit with spacers at all but they'd need to be hefty if you work out the details which ive guessed tbh.
RS4 et45- 8.5j ?
RS3 et50- 8j?
Means the inner clearance is 53mm less and they'll sit 27mm further under the arch if i've used the calculator correctly.
quattro81
All the gear.. No idea
Not knocking it, but out of curiosity why would you want rs4 wheels on the rs3?
JonnyG
if I got spacers they should fit?
They are a different offset to the A3 / RS3 and will stick out of the arch more by around 7mm I think (50 - 43), but that may be just OK.
Spacers will make it worse
Then there's the width of the actual wheel (the RS3 is 8J or 8.5J) - I'm sure the RS4 is probably wider, which will make them stick out even further than the offset alone.
MartayMcFly
Booooooost
Gold Supporter
Might need spiggot rings too, since pretty sure the RS4 will have 66.whatever mm hubs and the RS3 is 57.1mm
nshort10
There a set of mtm wheels on eBay I was looking at for the rs3 but they for a rs4 that why I was wondering if they will fit if not then I will just leave them. But it starting to sound as if it more work just to get them fitted ( even if they do fit)
nshort10
RS4 et45- 8.5j ?
RS3 et50- 8j?
prob best just to leave it and get a new set then that fit the rs3 correctly from mtm
