Hi gents,
I am having some issues with the breather system on my S3.
1) There was a lot of oil misting in around the breather and vacuum lines the inlet manifold.
2) I had the issue of the crankcase not being under vacuum. (shown by loosening oil cap and it being bounced around by the blow-by.
I know most of you guys that read this will say "catch can- simples" but I wanted to keep it OEM (ish) and now I've spent the money I am determined to get it to work. In short I replaced all of the breather system (silicon tubes from creation motorsport, hockey puck, PCV valve, jet suction pump, breather elbow near oil filter, brake servo pipes,checked all hard plastics for splits). I got rid of the misting which I think may have been due to a broken dipstick holder.
The crankcase is still not under vacuum after all of this!! I tried to trace back all of the connections and made sure they were tight and to see where I may be losing vaccum. When I remove the y shape breather from the block (still connected to hockey puck and the rest of PCV system) it is actually blowing out fumes rather than being under vacuum (which I assume is the correct mode of operation). I cant figure out where this positive pressure is coming from.
I have attached pics of the breather system before and after with the replacement parts in place- maybe it's something simple that I am missing...
Any help would be appreciated!
