the tarox pads are DS2500 if not mistaken just different naming , and better value for money and have a gd reputation, ive asked people arround and the tarox caliper is pretty gd and its not 4 but 6 pistons unlike the Brembo's and its different i suppose. however my question to Tuffy is if he would recomment the Tarox 6 pots, as im thinking of buying the calipers myself (sorry for hijacking thread)
Nothing wrong with LCR / Jnr GT 323's at all, and hardly old hat.
a 4 pot caliper is just that, a caliper with 4 pistons, 4 or 6 makes no odds really, it's all about having it correctly sized with the master cylinder to give the right balance of stopping power and pedal feel. there is of course the mono block / 2 part argument, and weight to consider, but the difference in these areas is hardly measurable.
being an OEM fit caliper, the LCR brembos are perfect in this respect, and provide brilliant stopping power and great pedal feel. Some bigger calipers will provide good power, but with an awful soft feel. Go too far the other way in the case of Porsche 996 rears, and you get poor stopping power, and rock hard wooden pedal.
It's not about bigger being better always, it's about choosing the right task for the job. you wouldn't use the anchor from the QE2 to stop your car rolling down a hill.....
it's far more about pad / disc choice to be honest.
I've currently got LCR 323mm brembos on my track car and Porsche 996 front Monoblock calipers with 330 discs on my daily. When using track pads, both setups perform exactly the same. Currently using track pads in the LCR 323's and ATE fast road porsche pads in the 996 brakes, and the LCR 323's absolutely wipe the floor with the bigger, technically better porsche brakes.
Sorry for hijackign the thread, i just really didnt want to start a new one. ive been also looking at the Brembo GT's front setup however would they fit under the 17inch std Avus wheels ? and would they fit one 17*7.5 Ultralegarra Wheel OZ's. been looking for almost 2 hrs on forums and couldnt find anything. advice appreciated !!!
thanks tuffy your a ledgend seriously , i also heard from threads that the pads and disc arent up to par esp the drilled ones ? think it would be fine going with just slotted and when they get worn down , replace them with DS2500's ?
yeah ive been at odds as i dont want to spend 1680$ for OZ's 17*7.5 and 1k Pounds for them not to fit and i dont want to throw my rubber got Pzero's so ill get 8mm Spacers for the front and rear and should be fine no ?
edit: also got 3 bottles of 500ml of Motul RBF 600 ready too
if i may ask as embarrassing as it is whats ET22 and ET32 sorry ....
yes we have gay rules in this country i.e. no decat exhausts on after market BOV, catch cans even if re-routed , the spacers , even loud music and exhuasts... and honking your horn would get you fined plenty, they end up ganging up on you with thier Ford XR6's which are horribly maintained
thank tuffy once again its saying id have roughly 25mm the inside of the wheel to the strut housing
