Hi all
I've recently got a '02 S3 BAM, and it has a slightly rough idle and seems to have a slight misfire at times.
The car was on longlife til 70k miles then oil every 7k from then on. I decided to investigate the breather and vac lines to see if they were the problem.
The oil breathers are in awful shape, can't actually see any splitts but they a basically collapsing and full of junk as is the PCV valve.
Under the manifold i can also see one of the vac lines is spliting.
I was planning on pulling all the pipes out and seeing if any can be salvaged and replacing the others, i see that Forge do some replacement pipes, but was wondering if anyone had any advise on parts to replace and other engine parts that might need cleaning/repairing as a result? or any other help would be really good!!
