You should be able to, the paddles should operate in all modes as far as I’m aware.Why can’t you change gear with the paddles in Sports Mode please.
As far as I’m aware S is an auto mode but can be interrupted by the paddles for gear shifts, if you then don’t interact with the paddles it’ll then default back into S mode. Same theory applies to D.OK well I have just checked again and if I’m in D mode then pull the gear lever down it goes into S mode but when I use the paddles it then goes back into M mode showing on the dashboard
So In my case S mode can only be used in auto is this right please
No matter what mode you're in if you use the paddles it'll say M on the dash, meaning manual. If you don't use the paddles for a while it'll go back to full auto (S/D). If you want full manual, flick back into sport then move the gearstick to the left, the car is now fully manual. It'll only upshift for you if you redline a gear or when slowing down and it needs the next gear.OK well I have just checked again and if I’m in D mode then pull the gear lever down it goes into S mode but when I use the paddles it then goes back into M mode showing on the dashboard
That is an error...move to the right., not to left for full manual mode
Here is the Audi manual description of use for the tiptronic auto transmission
Gear selection with selector lever
The tiptronic mode can be selected either with the vehicle stationary or on the move.
From position D/S, push the selector lever to the right into the tiptronic selector gate to activate tiptronic mode. As soon as the automatic gearbox has activated this mode, the letter Mwill appear on the display Fig. ►; e.g. M4 means that the vehicle is in 4th gear.
Briefly push the selector lever forwards -+- Fig. 109► to change up a gear.
Briefly pull the selector lever back -–- to change down a gear.
Gear selection with paddle levers*
You can use the paddle levers when the selector lever is in position D/S or M (= tiptronic selector gate).
To shift up a gear, briefly pull the paddle lever -+- Fig. 110►.
To shift down a gear, briefly pull the paddle lever -–-.
If you use the paddle levers when the selector lever is in positions D/S, the gearbox will remain in manual mode for a while. To switch back immediately to automatic mode after changing gears manually, pull the paddle lever -+- Fig. 110► for approximately 1 second.
If you want to use the paddle levers permanently, push the selector lever from position D/S to the right into the tiptronic selector gate.
The gearbox automatically shifts up or down into the next gear before a critical engine speed is reached.
The gearbox only allows manual gear changes if the engine speed would remain within the permissible range.
It is truly amazing what you can find in the manual.....you know that book in the glovebox...Yes, I am being cheeky.
You can move the gear selector to the left when you're in Drive, or after you put it into sport mode. In order to give yourself full manual mode, so to speak.So are you saying that if the gear level is full down to the inverted triangle in Sports Mode you can then move the gear-lever to the left
Me neither.....in fact didn't even know it was possible.I know it’s to the left for U.K. cars but never tried doing it when it’s in S mode
