S3 start up noise
Scottishdude
Hi folks my s3’s making strange noise on start up from over night, cold car, does it every time, but after started it’s fine,
Any help would be greatly appreciate, garage can’t determine what it is,
Scottishdude
Nah the cars air con is off, it very seldom on, it only does it first start of the day, it’s Bizzare, therefore hard to diagnosis
Scottishdude
They said if it was a pulley it would be present nearly all the time, I just need to keep an eye on it, someone might have came across it before, thanks for the ideas though guys, really good community here!
start it with the alternator belt off, if the noise stops then you can narrow it down to one of the pulleys, if its still there then you can rule out all aux belt driven components
as for whoever said it would be there all the time if it was belt related is wrong, my previous car would make a knocking noise when you rev it in neutral intermittently, after months of faffing around it ended up being the alternator pulley
it will give you a code and warning on the dash if you do that btw but the battery will let it run for quite a while
ccs3
Hey mate, did anything come from this?
Mine seems to do it once during start up but that's it.
Just to add to this, it doesn’t always do it, seems to be random.
Also, sometimes it will do it once, sometimes it will do it 2-3 times.
nothingness
Welcome to the layer cake, son
The little trumpet noise? Mine does this too, only on cold start, only when it's been raining, and only about 5 times. IIRC the answer I found was when one of the belts is wet.
ccs3
Interesting… Funny you mention rain, I’ve had my S3 for a month now and never noticed it until this week when the rain returned.
How long has yours behaved like this? Did you get an answer online or did you take it somewhere to get checked out?
nothingness
Since about 2 weeks after I bought it, which was during sunny weather. Just found out online, vwvortex or audizine I think.
pburv
Had the same noise from my 2015 S3. Got a bit louder the older it got. Was told it was the secondary air pump on cold start up. From memory I think it,s low down in the engine bay at the front? Was told not to worry about it so I didn,t lol
