I had my Scorpion system fitted towards the end of January but it hasn't been plain sailing. I'm very happy with the system now but thought I'd share my experience with everyone in case the information is of help to other S4 owners.
Fitment
After the initial fitting the rear pipes hung very low - you could see them clearly from the back of the car and they caught the ground over large bumps. The way the pipes ran around the rear diff was sloppy too - elsewhere the clearance was generally a uniform 20mm but here it was around 80-100mm and made the centre resonator also hang low. Finally it was rubbing on the transmission tunnel between the front and centre boxes. I went back to the fitter but they couldn't do anything as it was mounted correctly on its hangers so I got in touch with Scorpion technical support, who were absolutely fantastic. They personally collected my car and took it up to their workshop in Derby whilst I used one of their loan cars (a fully Scorpion-liveried Ford S-Max) and over the course of a week adjusted my system to fit my car perfectly, including custom tailpipes to suit the RS5 rear diffuser, at no cost. With the car back I'm now very happy with the fitment and can't rate Scorpion highly enough on their commitment to customer service.
I got in touch with a few S4 owners with Scorpion systems and some of them had seen the same low-hanging rear pipes. One owner had also had his car up at Scorpion for fitment issues, so it may be that there's a batch of systems which have manufacturing issues. Another factor is that I was informed that up to now the S4 system shared its design with the B8 RS4 and as such the run around the rear axle and diff didn't perfectly suit the S4. They've now create a system specifically for the S4 to address this.
Ground clearance
I love running my cars low so this may not be an issue for most, but the B8 platform has a fairly long wheelbase and a low floor so this is an important factor for me. The front and centre resonators on the Milltek system used to hang below the floor on my car but the Scorpion boxes sit neatly in the transmission tunnel which means I've gained a decent amount of ground clearance and therefore peace of mind over speed bumps and in car parks.
Sound level
Coming from a non-res Milltek I was shocked by how quiet this system is! That initial disappointment was soon replaced with a sense of relief once I reached the motorway and settled into a wonderfully peaceful 40 mile journey home. I'd got used to the bass tones and resonance of the Milltek system but hadn't realised how intrusive it was until it was gone. It must've been uncomfortable for my passengers. Over the course of the next 1000 miles the tone of the Scorpion system has deepened and improved significantly so it now produces the sound level others have described in this thread.
It really is remarkable what Scorpion have achieved I have to say! The noise level is negligible on normal driving, and on motorways in 7th gear under load (the main problem area) there is absolutely no drone at all. When you open the taps you get a definite increase in volume and tone over stock. It's no match for the Milltek non-res (we're not talking full-on V6 yowl) but it's purposeful and blends perfectly with the supercharger whine. Overall sound level is comparable with a Milltek resonated system but the tone is different. The Scorpion allows some of the V6 character through whereas the Milltek smoothes it out. Which you prefer it entirely subjective but I'm enjoying listening to the Scorpion system for sure, and actually being able to hear the engine again is a novelty! The engine and intake were largely drowned out by the Milltek non-res system. Important to note also that you still get the overrun pop when you back-off and the DSG bark on upshifts with the bedded-in Scorpion system.
I do occasionally miss blasting around my local back roads with a non-resonated system so I'm now considering the option of adding a pair of valves (or cut-outs) just before the rear boxes with a switch/controller inside the car. If I succeed in finding a high-quality switchable non-res solution I'll let you all know
