the pipes that need blanking off will be underneath your rear bumper
should be two rubber pipes about 5 or 6mm in diameter , you can blank them off here
some cars i have seen also have some valve and actuators inside the interior rear left panel in the floorspace at the bottom
some other cars have either never had this in place or have had it removed
the actuator for the second stage of the intake works at 5000rpm and is not easy to spot
you need two people to check this , one to rev the engine above 5000rpm and the other to look down on the front edge of the engine , the actuator itself is near the top of the front of the engine
if its moving fine , thats how it should be , if it isnt you could be in for a very very expensive repair , to repair the intake you have to buy the entire intake manifold as a little plastic and brass bush has worn and stopped working
audi in there wisdom dont sell this part on its own so you have to buy the entire manifold
anybody whom finds it isnt working please give me a shout as it is possible to repair it , but you have to be very very carefull
