S4 skirts+door trims fitting?
ian52
2000 a4 1.8tqs-yellow
perth
Just got mine today for my a4,not had a proper look at the car yet but i take it there is nothing funny when it comes to fitting them? I think they pulled the door trims off before they realised that they slide off when you take the screw out so they are a bit bent. Anybody know if you can but the bit that clips to the door on its own? All the cover bits that you see when fitter are fine. I never realised each trim was in two bits like that,i thought it would be the same as the a4 ones.
The S4 door trim plate fits onto the same pins as the A4 ones. Then the outer coloured bits clip onto the door trim bit
Yeah. Can you buy the plate part on its own? I should be able to get them all to go on ok but would be handy to know if i can get them.
i would have thought so
Its just strong velcro that holds the skirts at the sides then a bracket at the rear and it bolts to the front wing and a couple of small brackets go onto the seam where you jack the car up so support the skirts a bit. Should be pretty easy. The brackets for holding the small trim to the front wing and back arch are a bit goosed so i think i will just stick them on with tiger seal. I think i will just fit the skirts then sort out the sill trims. I have one but its not the best but i should be able to do something with it. Cant wait to get them on with the front bumper too.
the bumper will transform it, ian it did do mine
Did you use the a4 bumper struts? I have the s4 side brackets.
see other post, yes, lol
Thanks. I think i have everything to get all the s4 sideskirts and door mouldings done and the front bumper now. I just need the headlight washer covers. I wont get the skirts on untill i get new front wings that i should be getting early jan. Just cant wait to get it all done now.
yeah me too i have the front bumper on as you may know, the back bumper lower coded. i have all the cosmetic bits just a few screws etc required. i have pmed you
Edit:
the scuff panels was a mission to take off carefully, i have managed to take 1 side off. havent put the skirts on yet.
yes mate they are smaller than the standard a4 ones
yea not that much got mine from stoke audi (one of our site sponsors) £4 each plus £3 postage
They're just normal pre-facelift A4 brackets.
If you have a prefacelift car you wont need to change them.
The facelifted s4 has the mounting holes drilled in a different position as the prefacelift a4. Still fits right even with 2 screws !
Got the skirts on now and my new wings. Just need to put the door trims on after i tidy up the bottoms of the doors. Looks much better already and the votex rear bumper extension seems to fit in nicely with everything else. Ill get some pics up when i get the door trims on and the car is clean. I should have some s4 wheels in anthracite to replace my silver ones soon too so its getting there now.
me too, what did you do about the scuff trim? pics of that also plse
Just left it off for now. It was a pain to try and get it off without damaging it.
tell me about it! what did you use to get the sticky stuff of the sills?
every number you need, not sure which one you are after:
Rear bumper side holder-
8D9 807 571 AA near side
8D9 807 572AA offside
Front Bumper side holder
8D0 807 049 AA nearside
8D0 807 050 AA offside
Side trim parts
(1) 8D0-853-859-GRU trim
(1) 8D0-853-860-GRU trim
(1) 8D0-853-923-01C holder
(1) 8D0-853-924-01C holder
(10) 8D0-854-955-B-01C (-GRU) ring 89p
(10) 8A0-854-953 cover
(1) 8D0-853-941 strip
(1) 8D0-853-942 strip
(1) 8D0-854-973 clamp £13.65
(1) 8D0-854-974 clamp
(1) 8D0-854-977 clamp £12.80
(1) 8D0-854-978 clamp
(1) 8D0-854-983 clamp £5.43
(1) 8D0-854-984 clamp
(1) 8D0-853-959-A-GRU moulding
(1) 8D0-853-960-A-GRU moulding
(1) 8D0-853-969-A-GRU moulding
(1) 8D0-853-970-A-GRU moulding
(1) 8D0-853-953-B-GRU moulding
(1) 8D0-853-954-B-GRU moulding
(1) 8D0-853-963-B-GRU moulding
(1) 8D0-853-964-B-GRU moulding
(1) 8D0-853-974-B-GRU moulding
(1) 8D0-854-861-A-GRU cover
(1) 8D0-854-862-A-GRU cover
Not taken the tape off yet but it should roll off with your finger.
Ill try and get a couple of pics tonight of whats done so far. I thought i was getting some s4 wheels in anthracite soon but the guy sold them after agreeing price etc with me and just waiting on him getting back about a courier. Ill just have to get mine refurbed in that colour then when the better weather is here.
Some pics so far. The front wings look worse in the light of the camera flash than they doe for real. They are a slightly different shade still but not that bad.
New spoiler
jcb, was this for me? as i didnt ask for the part numbers i was asking if ian had take the sticky stuff off the sills
thanks anyway
726
