No - mine is bang up to date and I still have google earth - it was mentioned on another thread, but I think Audi may have done a u-turn on removing it.Is this the update that loses you google earth though? I’ll not be doing it if that’s the case
I think some browsers (that don't support java) don't work... best way to do it is make sure you have Java installed and download (save) the jnlp file, then once it is saved on your pc, double-click it and it will launch in Java. That will run a download/image maker tool, so you select your destination and it does the rest. I put it on a USB stick and then inserted that into the car and ran the update... I believe you can download direct to the car though, btu I've not tried that.How did you guys do the update? every single time I try to download from the Audi website it just fails!!! I gave up. Maybe their website was just having a bad day...
