- Joined
- Dec 14, 2014
- Messages
- 569
- Reaction score
- 75
- Points
- 28
Hi there
My 2013 8P Shape 1.6 tdi CAY Engine - has 67k miles
A week ago I noticed upon starting it for the first time on any day, for the first 5 minutes, the car would shake on idle, after 5 minutes, it would go away and the car would be faultless from then on. The next morning, I did an injector test via the VCDS and realised injector 4 was a bit all over the place, going upto +2.99, for the first 5 minutes and then going below -/+ 1.8, anyway, muggins here thought that it would be a good idea to swap injector 3 and 4, and then code them up via vcds to see whether it was the injector at fault or something deeper.
Changed them over and then the car was running rough all the time, and I noticed a tapping noise now, when the car was under load, even when warmed up.
Changed Injector 3 and 4 back over, and now it was running rough all the time, so thinking I maybe should have left it in the first place, where it wasn't even noticeable after 5 minutes.... too late for that though
I then took injector 3 and 4 out again, cleaned them and put them back in, when tightening up the injector clamp bolt, I snapped it into the cylinder head, so had to take out all 4 injectors, removed the rail, and took the rocker cover off. Drilled into the middle of the snapped bolt, cleaned up all the metal shavings, making sure none went into the middle of the engine, and luckily got the broken bolt out.
Put everything back together, got a new bolt from the dealers and put it back in. Took the car for a drive, glow plug light flashing and car looses all power, I pull up and notice diesel all over the engine, all over the rocker cover and around the injectors etc.
What's gone wrong? Injector seals? Not tightened the bolt up enough? a further problem?
Thanks guys
P.S I still didn't get to the bottom of the car shaking on idle, and now theres a tapping noise, and the car sounds rough as heck, compared to how it did before I messed around with it
Thanks guys
