Skoda Octavia Mk2 2010 CLCA engine not starting - no error codes in VCDS.
Divakaran
India
Dear All - i have SKODA OCTAVIA MK2 2010 model. I am from India, i had flat battery and recharged and ****** up to the car and started for running at idle. it was running fine and all ok. i went away from the car and in some time i heard a rough idle from the car and hearing the radiator kicking off to rotate with huge sound and the car stopped.
i checked the battery, its fine, the fuel pressure and flow is fine at both inlet side and at the HPP side. i have checked the compression and it clocks 21 bar. all the fuses are good in engine comportment, however the car is not starting at all. its crank well but not starting.
the radiator is keeps running when ever i switch on the ignition but not started the car. i checked the coolant temperature seasons G83 and G62 and it seems to be ok. the temperature needle in the dashboard is showing extreme right in red and if i remove the G83 and G62 wiring connections the needle is coming back to middle and radiator is stops running.
glow plugs are good, . oil level is good. below is my full auto scan from vcds. the car is still not starting. the air filter is clean, the fuel pump is clocking .5 pressure and flow is also good. i have not checked the injector yet. is there anything expert advice to check please help. the car is not starting yet and cranking well.
can you please advise with your expert help.
is there any other check i need to do to narrow down the issue? please help. no engine module error in VCDS.
thanks in advance
Sunday,08,August,2021,19:02:17:29955
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: TMBBNC1Z9AA151374 License Plate:
Chassis Type: 1Z-SK35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBBNC1Z9AA151374 Mileage: 116440km-72352miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 1010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 1010
Address 01: Engine (J623-CLCA) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 EJ HW: 03L 906 018 BR
Component: R4 2.0l TDI H20 9977
Revision: 42H20--- Serial number:
Coding: 00110012040500080000
Shop #: WSC 10259 663 00000
ASAM Dataset: EV_ECM20TDI01103L906018EJ 003008
ROD: EV_ECM20TDI01103L906018EJ.rod
VCID: 76B5E25848406D8BA5F-8022
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels:. 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AK HW: 1K0 907 379 AK
Component: MK70 M MASR 0104
Revision: 00H35001
Coding: 0017665
Shop #: WSC 33361 790 00000
VCID: 7BA3F36C7FE230E3DA1-802E
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 3T0 907 044 AS HW: 3T0 907 044 AS
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000001002
Shop #: WSC 73430 790 00000
ASAM Dataset: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_SK35.rod
VCID: 03538B8C0B924823921-8056
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
Component: BCM PQ35 H 103 0575
Revision: 00103 AG
Coding: 4E180AB8B00508C04008008011000124410000AE422085605C0440000000
VCID: 323D1E48E42831AB497-8066
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 28011 22 0601
Coding: 00D7B7
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 230110 05 54 0402
Coding: 0730ED
14 Faults Found:
00153 - Windshield Wiper Motor; Driver Side (V216)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 116447 km
Time Indication: 0
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
Term 50 Off
OFF
OFF
01493 - Bulb for Blinkers; Front Left (M5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 116447 km
Time Indication: 0
Date: 2015.12.30
Time: 00:38:25
Freeze Frame:
Term 15 On
Voltage: 11.80 V
ON
ON
Term 50 Off
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 1
Fault Frequency: 69
Reset counter: 156
Mileage: 116445 km
Time Indication: 0
Date: 2015.11.02
Time: 01:51:37
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
02394 - Parking Light Left Front (M1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 69
Reset counter: 156
Mileage: 116445 km
Time Indication: 0
Date: 2015.11.02
Time: 01:51:38
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
Term 50 Off
OFF
OFF
02395 - Parking Light Front Right (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 69
Reset counter: 156
Mileage: 116445 km
Time Indication: 0
Date: 2015.11.02
Time: 01:51:38
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
Term 50 Off
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 61
Reset counter: 156
Mileage: 116445 km
Time Indication: 0
Date: 2015.11.02
Time: 01:51:38
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
01495 - Bulb for High-Beams; Left (M30)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 61
Reset counter: 156
Mileage: 116445 km
Time Indication: 0
Date: 2015.11.02
Time: 01:51:38
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 54
Reset counter: 156
Mileage: 116445 km
Time Indication: 0
Date: 2015.11.02
Time: 01:51:40
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 50
Reset counter: 156
Mileage: 116445 km
Time Indication: 0
Date: 2015.11.02
Time: 01:51:41
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 50
Reset counter: 156
Mileage: 116445 km
Time Indication: 0
Date: 2015.11.02
Time: 01:51:41
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 116446 km
Time Indication: 0
Date: 2015.11.09
Time: 17:43:18
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
Term 50 Off
OFF
OFF
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 116446 km
Time Indication: 0
Date: 2015.11.09
Time: 17:43:18
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
Term 50 Off
OFF
OFF
00907 - Intervention load Management
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 196
Mileage: 116447 km
Time Indication: 0
Date: 2015.12.28
Time: 00:55:23
Freeze Frame:
Term 15 On
Voltage: 11.55 V
ON
ON
Term 50 Off
OFF
OFF
01497 - Bulb for Blinkers; Front Right (M7)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 116447 km
Time Indication: 0
Date: 2015.12.30
Time: 00:38:25
Freeze Frame:
Term 15 On
Voltage: 11.80 V
ON
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:. 1Z0-919-475-V1.clb
Part No SW: 1Z0 919 475 B HW: 1Z0 919 475
Component: PARKHILFE 4K H06 0006
Revision: -------- Serial number: 66641000904029
Coding: 100001
VCID: 40D944805A84933BCF3-8014
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 07 AIRBAG VW52 025 2400
Revision: 06025000 Serial number: 0037TR06BB8G
Coding: 0012343
VCID: 7DA7FD7461F63ED3E45-8028
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0000003
VCID: 025D8E881808412B997-8056
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 1Z0 920 803 G HW: 1Z0 920 803 G
Component: KOMBI H06 0305
Serial number: 00000000000000
Coding: 110800
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
VCID: 38292C6002D4DBFB773-806C
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K101270083
Coding: E9A07F06000202001303
VCID: 698FB924057EB27338D-803C
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 116446 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 116446 km
Time Indication: 0
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 116447 km
Time Indication: 0
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H06 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DC6280CF8B96B317-803E
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2114
Coding: 0004854
VCID: 76B5E25844C06D8BA5F-8022
4 Faults Found:
00120 - Outside Warning Light/Door exit Light Driver Side
00109 - Left Mirror Turn Signal Lamp (L131)
00131 - Outside Door Handle Illumination/mirror Light Driver Side
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 68 3001
Revision: 00H17000
VCID: 313F1144ED2E0AB330D-8064
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Battery Volts: 12.1 V
PD
Temperature: 34.0°C
Count: 2
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0004854
VCID: 48C95CA07EB4AB7B073-801C
6 Faults Found:
00121 - Outside Warning Light/Door exit Light Passenger Side
00110 - Right Mirror Turn Signal Lamp (L132)
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 161 F HW: 1Z0 035 161 F
Component: SWING 009 0065
Revision: 0I001001 Serial number: SKZ1Z2K8364845
Coding: 0D0004000001
VCID: 313F1144E12E0AB330D-8064
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 33361 790 1012544
VCID: 323D1E48E82831AB497-8066
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 33331B4C173238A3421-8066
1 Fault Found:
02071 - Local Databus
End----(Elapsed Time: 01:01, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Porn Free Porn Tube
Porn Movies and XXX Movies
XXX Videos Porn XXX
XXX Porn Tube Videos XXX Movies XXX
Hot Porn Video and Porn Movies.
Free XXX Porn Tube & Videos.
Best XXX Video & Movies.
Porn XXX Video Sex Porn Videos.
Sex XXX Sex Movies Porn Movie.
Watch now the best free porn!!
Porn Tube, 100% Free
XXX Videos, Sex Movies, Porn Videos
Porn XXX,Free Sex,Porn HD,Porn Movies
Porn Videos Tube, Porn Video XXX
XXX Movies, XXX Video Tube
Best Porn Websites. Watch Best Porn Videos for FREE:
https://xxxpornvideostube.org - XXX Video Tube Porn Videos Tube - XXX Porn Videos Tube.
https://sexjapanesexxx.com - Sex Japanese XXX.
https://gayporn777.com - Gay Porn XXX Tube Free Gay Porn Videos - Gay Porn.
https://porn-video7.com - Porn XXX Video - Free Porn XXX Videos Tube.
https://sexylady24.com - Sexy Lady Video.
Have fun watching porn on best porn websites.
Have a nice watch :)
Thank you :D
XXX Porn Videos XXX Movies b0cbe6b
Hi All - i was away for while due to various medical reason, i just back and checked the complete car mechanical part, circuits etc. the car is still not starting and when i checked the compression its perfect, the fuel from the fuel tank and the electrical pump are perfect. but the fuel is not coming out from the high pressure pump. i removed the metering devices and tried to check whether the signals are comping in the metering device by cranking, the car is started that means when I remove the metering device and not connected to the HPP the car is starting. do you have any idea why is this sir? please help
hi - greetings and hope all will have a great weekend. please help me for the situation, the car is starting only if i remove the metering device from the high pressure pump and will that be the metering device fault? is there way to test these valves? please advise.
hi All good morning and hope all should be doing great. while i am waiting for some expert advise from you i continued my investigation and following is my observation. this metering device N290 is normally open solenoid valve and if you give the signal, the valve closes. so if i remove the signal connectors the valve is in open condition and allows more fuel to the rail and VCDS reports fuel high pressure and shuts the car. if i connect the supply connectors back to this valve the valve closes and no fuel to rail and car is not starting. short story short, i yet to trace the cable from the valve to the fuse holders but i checked all the fuses. all i need how will the ECM controls this valve, technically the ECM closes the valve when the fuel pressure is high and more fuel comes and so on. i think it take the input from G247 fuel pressure sensor on the distributor and also the fuel pressure regulator N276 which builds and release the pressure as needed. I checked the return fuel pip for clogging and its free. but engine module in VCDS is not reporting any error other than the coolant temperature is very high if i connect the coolant temperature sensor in the radiator outlet G83 and in the coolant inlet connects to the block G62 and because of this the temperature sensor reading in the dashboard insert is showing extreme red. I yet to check the Oil level and oil temperature sender - G266 under the engine block cover and yet to trace these cables back to fuse tray for any rat bites. is there any other technical advise please help me. i am trying to fix this over this weekend please help. appreciate all your help in advance
I
3K
imported_cheekiestmunkee
I
