Sluggish Gear Changes
Jones.RS3
Newcastle
Hi everyone!
Anyone know what can cause sluggish gear changes? It's the 7 speed DQ380/381 box. I've already forked out for a new gearbox and had that fitted with new mechatronics and issue still the same. I'm running out of options now Almost sounds as though it's slipping or just being lazy changing gear.
Sent from my LYA-L09 using Tapatalk
Have to tried doing a dsg adaptation with vcds or obd11? I would try that 1st. Also check to see if the dsg has enough oil in it. Are you running stock dsg tune?
Sent from my SM-N975U1 using Tapatalk
It's just had a new gearbox fitted so just been fully serviced including fresh gearbox fluid. Stock tune also, was previously mapped ECU and TCU but both completely back to standard. No error codes either as been scanned multiple times. Don't know where to look next :(
I would try a DSG adaptation through either vcds or obd11.
