smoke comming out of the exhaust
I
imported_so_cal003
Guest
i have a 98 a4 1.8t and recently had the oil changed about two weeks ago. the car has 63,000 miles on it and right after the oil change the car started burning oil. smoke comes out from the exhaust now. there is no oil in the overflow compartment so i'm ruling out a cracked head gasket and it doesn't over heat. i was just wondering if it's just the turbo gone bad the car does feel a bit more sluggish.
Can you feel the car boost anymore?
Hopefully the oil change was done properly as the turbo can blow as soon as there is no oil running through the bairings. IMO
Was it smoking when the engine was running?
But seriously check the level because if it has been overfilled you will experience this problem.
